AW: [Mapbender-dev] Reminder: Code Conventions
Arnulf Christl
arnulf.christl at wheregroup.com
Wed Jan 24 08:00:45 EST 2007
Christoph Baudson wrote:
> Hello devs,
>> I am a little bit confused about the discussion on compressed JS Code.
>> If I understand it correctly, this would mean there is a "source" or
>> raw JS code following the conventions of the packing routine (with
>> comments inline, correct semi-colons) that lives e.g. in the
>> repository, but a released version would use the compressed JS (or
>> the JS is compressed on the fly). Is that the case?
> This is not intended to be a standard way of distributing Mapbender, but
> might be interesting for special applications where speed is essential
> (and you may not be interested in changing the sources frequently). I was
> thinking f.e. about the Mapbender installation at www.mapbender.org
> (column on the right). It is just a basic demo and should load as fast as
> possible. I guess that compression is an interesting idea worth keeping in
> mind.
> Cheers,
> Christoph
Uli and me have discussed this years ago but did not have a tool to do that automagically. I am the first to plusone this, we are wasting loads of bandwidth with "wfs_featuretype_element" which could also be "x3" which is 92.7% smaller. This code should only be used on productive portal sites, development will always be done with full names "wfs_featuretype_element".
Regards, Arnulf.
More information about the Mapbender_dev
