[Mapbender-dev] Code Conventions (first summary)
Uli Rothstein (WhereGroup) uli.rothstein at wheregroup.com
Tue Jan 30 02:54:15 EST 2007
Hi all,
Christoph Baudson (WhereGroup) schrieb:
> Hi everybody,
> to accelerate the process of agreement on the conventions, I would like
> to summarize our discussion:
> * The code conventions say "performance is not a good reason to avoid
> commenting" (thanks for the reminder, Marko)
> * Marc proposed a PHP-Doc style documentation for both PHP and JS,
> seconded by Marko.
jep, PHP-Doc style is a good proposal, so we can use some tools to extract the
documentation - although I think that the wiki is the better alternative for the
documentation. There are two advantages: we've one format (wiki) for all
purposes and we have a history.
But maybe we could use both and extract the php-doc-style comments into the wiki?
> * Marc introduced the packing algorithm used by jQuery:
> http://dean.edwards.name/packer/usage/
> Using this packing algorithm would result in additional rules:
> - "terminate every statement by a semicolon (even functions!)" (although
> I don't understand why the if-statement in the sample is not
> terminated..any ideas? http://dean.edwards.name/packer/usage/sample.html)
that's not very consequent and stringent. And the terminating semicolon behind
the bracket of the function-body is seriously ugly! I've never seen that before.
> - "always use curly braces, even if the block consists of only one line"
> (using the packer would be optional)
Some additional proposals:
* I think it would be helpful to declare the variable which come from 'outside'
via GET, POST, SESSION etc. in the header
* so we should provide some templates in our mapbender-org-wiki which could be
imported in the IDE
best regards
Uli
> I would like to invite everyone who disagrees with these statements (or
> has corrections) to come up with their arguments, so that an agreement
> can be reached soon.
> Thanks for your time,
> Christoph
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
        Ulrich Rothstein
    WhereGroup GmbH & Co.KG
        Siemensstraße 8
         53121 Bonn
           GERMANY
          uli at osgeo.org
        www.wheregroup.com
        www.mapbender.org
Zentrale:  ++49 (0) 228 909038 0
Durchwahl: ++49 (0) 228 909038 17
Fax:       ++49 (0) 228 909038 11
ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben ihre Fusion als
WhereGroup zum 1.1.2007 bekannt gegeben.
Daher ändern sich ab Januar 2007 die Email Adressen und Telefonnummern.
More information about the Mapbender_dev mailing list
