[Mapbender-dev] PKs for all tables?
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Wed Jan 31 02:22:48 EST 2007
Hi Marko,
Samson, Marko schrieb:
>> -----Ursprüngliche Nachricht-----
>> Von: mapbender_dev-bounces at lists.osgeo.org
>> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
>> Gesendet: Dienstag, 30. Januar 2007 10:11
>> An: Mapbender Developer List
>> Betreff: Re: [Mapbender-dev] Test of RC1 / some thoughts
>> dear list-members,
>> Marc Jansen schrieb:
>>> Hey Marko, hey List,
>>>> 2. Test of upgrading a 2.4 version
>>>> - everything seems to work fine, too. (The first time
>> I did the
>>>> upgrade, I had all entries of gui_layers twice. Don't know, what I
>>>> did wrong. Whatever, the second time everything worked
>> pretty nice. )
>>>> Idea:
>>>> I saw, that you set "default_with_oids = true" in the new pgsql
>>>> schema, but wouldn't there be a chance for grouped
>> primary-keys for
>>>> all the pk-less tables, for example the table gui_layer with a
>>>> grouped-pk of fkey_gui_id and fkey_layer_id to prevent
>> double entries.
>>>> (same idea for all other tables without PK like
>>>> gui_layer,gui_wfs,gui_wms,...)
>>> I second that, if there are no other relevant issues. I can not see
>>> any
>>> -- do you? A grouped PK should be the right way to handle
>> theses tables.
>>>> Or is there a reason, why there are no PKs at some tables? In my
>>>> opinion, there is no logic of having two entries, for example with
>>>> the same fkey_gui_id and fkey_layer_id in table gui_layer.
>>> Yipp, speaking from a database view of things, one does not
>> need two
>>> entries with the same values in the field you named. Am I missing
>>> something?
>> I don't now. There may be some technical reasons to publish a
>> layer twice, because nonexisting transparency of services for
>> example. So you have more flexibility for the arrangement of
>> layers. (But I've never seen such constructions in reality...)
> But this now can be managed very easy with the new treefolder to move the different layers up or down to handle that problem(additional to the wms_preferences modul). Or have I misunderstood what you meant?
You're right. But we have some more GeoDataExplorer, for example the
configurable one... Howerver, if we don't need to publish layer twice, we should
have a unique fkey_wms_id - fkey_layer_id combination.
> But there are several tables without pks. I think, for a stable datastructure it is advantageous to have pks at every table.
That's definitively true. Is someone able to list the missing pks and to create
the corresponding sql-statements, if all dev-members agree?
Thanks for your hints Marko and best regards
Uli
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Ulrich Rothstein
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
GERMANY
uli at osgeo.org
www.wheregroup.com
www.mapbender.org
Zentrale: ++49 (0) 228 909038 0
Durchwahl: ++49 (0) 228 909038 17
Fax: ++49 (0) 228 909038 11
ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben ihre Fusion als
WhereGroup zum 1.1.2007 bekannt gegeben.
Daher ändern sich ab Januar 2007 die Email Adressen und Telefonnummern.
More information about the Mapbender_dev
