AW: [Mapbender-dev] PKs for all tables?
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Wed Jan 31 05:43:11 EST 2007
Hi Marko,
Samson, Marko schrieb:
> Here are the first pks:
> ALTER TABLE ONLY gui_layer
> ADD CONSTRAINT pk_gui_layer PRIMARY KEY (fkey_gui_id,fkey_layer_id);
> ALTER TABLE ONLY gui_wfs
> ADD CONSTRAINT pk_gui_wfs PRIMARY KEY (fkey_gui_id,fkey_wfs_id);
> ALTER TABLE ONLY gui_wms
> ADD CONSTRAINT pk_gui_wms PRIMARY KEY (fkey_gui_id,fkey_wms_id);
> ALTER TABLE ONLY layer_keyword
> ADD CONSTRAINT pk_layer_keyword PRIMARY KEY (fkey_layer_id,fkey_keyword_id);
> ALTER TABLE ONLY mb_user_wmc
> ADD CONSTRAINT pk_user_wmc PRIMARY KEY (wmc_id);
> ALTER TABLE ONLY wfs_element
> ADD CONSTRAINT pk_wfs_element PRIMARY KEY (fkey_featuretype_id,element_id);
> ALTER TABLE ONLY wms_format
> ADD CONSTRAINT pk_wms_format PRIMARY KEY (fkey_wms_id,data_type,data_format);
> ALTER TABLE ONLY wms_md_topic_category
> ADD CONSTRAINT pk_md_topic_category PRIMARY KEY (fkey_wms_id,fkey_md_topic_category_id);
> ALTER TABLE ONLY wms_srs
> ADD CONSTRAINT pk_wms_srs PRIMARY KEY (fkey_wms_id,wms_srs);
> There are some more tables without a pk....still working on it (some have many double and other weird entries(for example layer_epsg). that has to be cleaned first)....
Thanks a lot. There is a discription for a workaround for double entries in the
talbe layer_epsg:
http://www.mapbender.org/index.php/Database_Changes_2.4.1
best regards
Uli
> Please have a look at it. But I think this should be alright so far.
> Gruß,
> Marko
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Achtung, neue Telefonnummer!
> Tel.: 0251/91797 - 169
> Mail: marko.samson at wald-und-holz.nrw.de
>> -----Ursprüngliche Nachricht-----
>> Von: mapbender_dev-bounces at lists.osgeo.org
>> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
>> Gesendet: Mittwoch, 31. Januar 2007 08:23
>> An: Mapbender Developer List
>> Betreff: Re: [Mapbender-dev] PKs for all tables?
>> Hi Marko,
>>>> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Uli
>>>> Gesendet: Dienstag, 30. Januar 2007 10:11
>>>> Betreff: Re: [Mapbender-dev] Test of RC1 / some thoughts
>>>> dear list-members,
>>>> Marc Jansen schrieb:
>>>>> Hey Marko, hey List,
>>>>>> 2. Test of upgrading a 2.4 version
>>>>>> - everything seems to work fine, too. (The first time
>>>> I did the
>>>>>> upgrade, I had all entries of gui_layers twice. Don't
>> know, what I
>>>>>> did wrong. Whatever, the second time everything worked
>>>> pretty nice. )
>>>>>> Idea:
>>>>>> I saw, that you set "default_with_oids = true" in the new pgsql
>>>>>> schema, but wouldn't there be a chance for grouped
>>>> primary-keys for
>>>>>> all the pk-less tables, for example the table gui_layer with a
>>>>>> grouped-pk of fkey_gui_id and fkey_layer_id to prevent
>>>> double entries.
>>>>>> (same idea for all other tables without PK like
>>>>>> gui_layer,gui_wfs,gui_wms,...)
>>>>> I second that, if there are no other relevant issues. I
>> can not see
>>>>> any
>>>>> -- do you? A grouped PK should be the right way to handle
>>>> theses tables.
>>>>>> Or is there a reason, why there are no PKs at some
>> tables? In my
>>>>>> opinion, there is no logic of having two entries, for
>> example with
>>>>>> the same fkey_gui_id and fkey_layer_id in table gui_layer.
>>>>> Yipp, speaking from a database view of things, one does not
>>>> need two
>>>>> entries with the same values in the field you named. Am I missing
>>>>> something?
>>>> I don't now. There may be some technical reasons to
>> publish a layer
>>>> twice, because nonexisting transparency of services for
>> example. So
>>>> you have more flexibility for the arrangement of layers. (But I've
>>>> never seen such constructions in reality...)
>>> But this now can be managed very easy with the new
>> treefolder to move the different layers up or down to handle
>> that problem(additional to the wms_preferences modul). Or
>> have I misunderstood what you meant?
>> You're right. But we have some more GeoDataExplorer, for
>> example the configurable one... Howerver, if we don't need to
>> publish layer twice, we should have a unique fkey_wms_id -
>> fkey_layer_id combination.
>>> But there are several tables without pks. I think, for a
>> stable datastructure it is advantageous to have pks at every table.
>> That's definitively true. Is someone able to list the missing
>> pks and to create the corresponding sql-statements, if all
>> dev-members agree?
>> Thanks for your hints Marko and best regards Uli
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Ulrich Rothstein
>> WhereGroup GmbH & Co.KG
>> Siemensstraße 8
>> 53121 Bonn
>> GERMANY
>> uli at osgeo.org
>> www.wheregroup.com
>> www.mapbender.org
>> Zentrale: ++49 (0) 228 909038 0
>> Durchwahl: ++49 (0) 228 909038 17
>> Fax: ++49 (0) 228 909038 11
>> ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben
>> ihre Fusion als WhereGroup zum 1.1.2007 bekannt gegeben.
>> Daher ändern sich ab Januar 2007 die Email Adressen und
>> Telefonnummern.
Ulrich Rothstein
Siemensstraße 8
53121 Bonn
GERMANY
uli at osgeo.org
www.wheregroup.com
www.mapbender.org
ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben ihre Fusion als
Daher ändern sich ab Januar 2007 die Email Adressen und Telefonnummern.
More information about the Mapbender_dev
