AW: [Mapbender-dev] PKs for all tables?
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Wed Jan 31 08:41:07 EST 2007
ALTER TABLE ONLY wfs_featuretype_namespace ADD CONSTRAINT pk_featuretype_namespace PRIMARY KEY (fkey_wfs_id,fkey_featuretype_id,namespace);
ALTER TABLE ONLY mb_monitor ADD CONSTRAINT pk_mb_monitor PRIMARY KEY (upload_id, fkey_wms_id);
ALTER TABLE ONLY mb_log ADD CONSTRAINT pk_mb_log PRIMARY KEY (id);
layer epsg had to be to cleaned. rc1 table backup after cleaning at zip-file.....
I had to delete one WMS, but I forgot the name. Something like eusoil or something like that (layer_id was 13667?)
ALTER TABLE ONLY layer_epsg ADD CONSTRAINT pk_layer_epsg PRIMARY KEY (fkey_layer_id,epsg);
layer style has to be cleaned, but I think the pk should be like this. but I'm not sure!:
ALTER TABLE ONLY layer_style ADD CONSTRAINT pk_layer_style PRIMARY KEY (fkey_layer_id,name);
Gruß,
Marko
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Achtung, neue Telefonnummer!
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
> -----Ursprüngliche Nachricht-----
> Von: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
> Uli Rothstein (WhereGroup)
> Gesendet: Mittwoch, 31. Januar 2007 08:23
> An: Mapbender Developer List
> Betreff: Re: [Mapbender-dev] PKs for all tables?
> Hi Marko,
> >> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Uli
> >> Gesendet: Dienstag, 30. Januar 2007 10:11
> >> Betreff: Re: [Mapbender-dev] Test of RC1 / some thoughts
> >> dear list-members,
> >> Marc Jansen schrieb:
> >>> Hey Marko, hey List,
> >>>> 2. Test of upgrading a 2.4 version
> >>>> - everything seems to work fine, too. (The first time
> >> I did the
> >>>> upgrade, I had all entries of gui_layers twice. Don't
> know, what I
> >>>> did wrong. Whatever, the second time everything worked
> >> pretty nice. )
> >>>> Idea:
> >>>> I saw, that you set "default_with_oids = true" in the new pgsql
> >>>> schema, but wouldn't there be a chance for grouped
> >> primary-keys for
> >>>> all the pk-less tables, for example the table gui_layer with a
> >>>> grouped-pk of fkey_gui_id and fkey_layer_id to prevent
> >> double entries.
> >>>> (same idea for all other tables without PK like
> >>>> gui_layer,gui_wfs,gui_wms,...)
> >>> I second that, if there are no other relevant issues. I
> can not see
> >>> any
> >>> -- do you? A grouped PK should be the right way to handle
> >> theses tables.
> >>>> Or is there a reason, why there are no PKs at some
> tables? In my
> >>>> opinion, there is no logic of having two entries, for
> example with
> >>>> the same fkey_gui_id and fkey_layer_id in table gui_layer.
> >>> Yipp, speaking from a database view of things, one does not
> >> need two
> >>> entries with the same values in the field you named. Am I missing
> >>> something?
> >> I don't now. There may be some technical reasons to
> publish a layer
> >> twice, because nonexisting transparency of services for
> example. So
> >> you have more flexibility for the arrangement of layers. (But I've
> >> never seen such constructions in reality...)
> > But this now can be managed very easy with the new
> treefolder to move the different layers up or down to handle
> that problem(additional to the wms_preferences modul). Or
> have I misunderstood what you meant?
> You're right. But we have some more GeoDataExplorer, for
> example the configurable one... Howerver, if we don't need to
> publish layer twice, we should have a unique fkey_wms_id -
> fkey_layer_id combination.
> > But there are several tables without pks. I think, for a
> stable datastructure it is advantageous to have pks at every table.
> That's definitively true. Is someone able to list the missing
> pks and to create the corresponding sql-statements, if all
> dev-members agree?
> Thanks for your hints Marko and best regards Uli
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Ulrich Rothstein
> WhereGroup GmbH & Co.KG
> Siemensstraße 8
> 53121 Bonn
> GERMANY
> uli.rothstein at wheregroup.com
> uli at osgeo.org
> www.wheregroup.com
> www.mapbender.org
> Zentrale: ++49 (0) 228 909038 0
> Durchwahl: ++49 (0) 228 909038 17
> Fax: ++49 (0) 228 909038 11
> ACHTUNG: Die Firmen Geo-Consortium, CCGIS und KARTA.GO haben
> ihre Fusion als WhereGroup zum 1.1.2007 bekannt gegeben.
> Daher ändern sich ab Januar 2007 die Email Adressen und
> Telefonnummern.
Type: application/x-zip-compressed
Desc: layer_epsg.zip
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20070131/ede38d82/layer_epsg-0001.bin
More information about the Mapbender_dev
