[Mapbender-dev] Mapbender 2.4.2 rc1 - Postgres iso
Thomas Baschetti
Thomas.Baschetti at gmx.de
Thu Jul 12 10:21:56 EDT 2007
Hi Christoph,
that's not what i meant ;-)
In mapbender_2.4.2_rc1.zip the files
resources\db\postgresql\iso \pgsql_data.sql
and
resources\db\postgresql\utf8\pgsql_data.sql
are just the same, bit by bit, no conversion was done on this.
Only the postgres-dump, the mysql-dump seems to be ok.
Bye
Thomas
> Hi Thomas,
> thanks for testing.
> I'm not entirely sure on how to create the ISO dump. What I did was the
> following:
> -generate the utf8 dump
> -convert the dump via "iconv"
> -ignore the violations (iconv option -c)
> I assumed that I succeeded, as I could import the dump in a MySQL
> database (with charset latin1_general_cs)
> Nevertheless I had opened a trac ticket
> http://trac.osgeo.org/mapbender/ticket/58
> If anyone has any comments of how to do the conversion properly, please
> let us know. The next release is coming up... :-)
> Cheers
> Christoph
Psssst! Schon vom neuen GMX MultiMessenger gehört?
Der kanns mit allen: http://www.gmx.net/de/go/multimessenger
More information about the Mapbender_dev
