[Mapbender-dev] class_gml2.php
Christoph Ratke ratke at geoinformationsdienst.de
Fri Jul 13 05:34:29 EDT 2007
Hi Christoph,
file attached. Search for the XXX to see diffs (just two lines).
best,
Christoph
Am Donnerstag, den 12.07.2007, 15:27 +0200 schrieb Christoph Baudson
(WhereGroup):
> Hi Christoph,
> I would very much like to see your addition, please send me the file.
> Thanks a lot,
> Christoph
> Christoph Ratke schrieb:
> > Hi list,
> > I was testing the Gazetteer WFS module. When searching objects with
> > inner polygons (with 'geometry ilands') I did not get the outer polygon
> > but an inner one as gazetteer result. Maybe that was intended but it was
> > not correct for me.
> > I sligthly modified the class class/class_gml2.php and now all inner and
> > the outer polygons are shown. All I did was adding two lines,
> > (incrementing a geometry counter, $cnt_geom) in function
> > parse_xml($data).
> > I don't know if there is a need for but I could comment that further or
> > send the class_gml2 if you like.
> > Best,
> > Christoph Ratke
Christoph Ratke
Geoinformationsdienst GmbH
Götzenbreite 10, 37124 Rosdorf
Geschäftsführer: Dirk Feise
HRB:3062, Amtsgericht Göttingen
Tel.:   ++49 551-7890420
Fax.:   ++49 551-7890429
Email: ratke at geoinformationsdienst.de
Web: http://www.geoinformationsdienst.de
Type: application/x-php
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20070713/eb9d9958/class_gml2.bin
More information about the Mapbender_dev mailing list
