[Mapbender-dev] Mapbender work group I18N
Michael Schulz mschulz at webgis.de
Wed Jul 25 10:58:35 EDT 2007
Hi Christoph,
see attached files for system with debian sarge and suse 10.1 .
Cheers, Michael
2007/7/25, Christoph Baudson <christoph.baudson at wheregroup.com>:
> Hi,
> See http://www.mapbender.org/index.php/Internationalisation
> we would like to internationalize Mapbender. We would need some feedback
> on how different platforms behave with the setlocale function. Could you
> please run the attached script and send the generated file
> (locales-logfile.txt) back to the list and tell us on which platform it
> run.
> We would appreciate if you could run the test as soon as possible.
> Thanks
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
uname: Linux h1198341 2.6.8-3-686 #1 Tue Dec 5 21:26:38 UTC 2006 i686
$_SERVER['OS']: not set
identified as: linux
Locale it_IT.utf8 not found
locale de_DE.utf8 ok on linux
Locale en_US.utf8 not found
uname: Linux suse64-1 2.6.16.13-4-default #1 Wed May 3 04:53:23 UTC 2006 x86_64
locale it_IT.utf8 ok on linux
locale en_US.utf8 ok on linux
More information about the Mapbender_dev mailing list
