[Mapbender-dev] Mapbender work group I18N
Christoph Ratke ratke at geoinformationsdienst.de
Wed Jul 25 11:20:58 EDT 2007
Hi Christoph,
file attached for Ubuntu feisty (7.04).
best,
Christoph Ratke
Am Mittwoch, den 25.07.2007, 16:58 +0200 schrieb Michael Schulz:
> Hi Christoph,
> see attached files for system with debian sarge and suse 10.1 .
> Cheers, Michael
> 2007/7/25, Christoph Baudson <christoph.baudson at wheregroup.com>:
> > Hi,
> > See http://www.mapbender.org/index.php/Internationalisation
> > we would like to internationalize Mapbender. We would need some feedback
> > on how different platforms behave with the setlocale function. Could you
> > please run the attached script and send the generated file
> > (locales-logfile.txt) back to the list and tell us on which platform it
> > run.
> > We would appreciate if you could run the test as soon as possible.
> > Thanks
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Christoph Ratke
Geoinformationsdienst GmbH
Götzenbreite 10, 37124 Rosdorf
Geschäftsführer: Dirk Feise
HRB:3062, Amtsgericht Göttingen
Tel.:   ++49 551-7890420
Fax.:   ++49 551-7890429
Email: ratke at geoinformationsdienst.de
Web: http://www.geoinformationsdienst.de
uname: Linux p18kac7 2.6.20-16-generic #2 SMP Thu Jun 7 20:19:32 UTC 2007 i686
$_SERVER['OS']: not set
identified as: linux
Locale it_IT.utf8 not found
locale de_DE.utf8 ok on linux
locale en_US.utf8 ok on linux
More information about the Mapbender_dev mailing list
