[Mapbender-dev] Mapbender work group I18N
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Mon Jul 30 08:10:54 EDT 2007
Thanks for your overwhelming response. The internationalization work
group definitely benefitted from your help.
Take a look at our results at
http://www.mapbender.org/index.php/Internationalisation
Christoph
Christoph Ratke schrieb:
> Hi Christoph,
> file attached for Ubuntu feisty (7.04).
> best,
> Christoph Ratke
> Am Mittwoch, den 25.07.2007, 16:58 +0200 schrieb Michael Schulz:
>> Hi Christoph,
>> see attached files for system with debian sarge and suse 10.1 .
>> Cheers, Michael
>> 2007/7/25, Christoph Baudson <christoph.baudson at wheregroup.com>:
>>> Hi,
>>> See http://www.mapbender.org/index.php/Internationalisation
>>> we would like to internationalize Mapbender. We would need some feedback
>>> on how different platforms behave with the setlocale function. Could you
>>> please run the attached script and send the generated file
>>> (locales-logfile.txt) back to the list and tell us on which platform it
>>> run.
>>> We would appreciate if you could run the test as soon as possible.
>>> Thanks
>>> Mapbender_dev mailing list
>>> Mapbender_dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> uname: Linux p18kac7 2.6.20-16-generic #2 SMP Thu Jun 7 20:19:32 UTC 2007 i686
>> $_SERVER['OS']: not set
>> identified as: linux
>> Locale it_IT.utf8 not found
>> locale de_DE.utf8 ok on linux
>> locale en_US.utf8 ok on linux
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:info at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Baudson Christoph
More information about the Mapbender_dev mailing list
