[Mapbender-dev] [Fwd: [SAC ] Notification proceedures (was Subversion vhost migration underway)]
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue Mar 6 03:16:10 EST 2007
> SVN operation needs a module maintainer. I am currently subscribed to
> SAC and will keep on reporting of issues to dev if they affect the
> Mapbender infrastructure but only as replacement. I suggest that a
> regular commiter signs up to SAC and makes herself known as module
> maintainter for mapbender system operation at OSGeo. This might also
> involve some volunteer work for OSGeo and if it is only helping other
> projects get up to speed.
Is this what you mean by Operation Administrator? If that's so, I will
do it. Is "Operation Administrator" a good name? Maybe we can assign
these tasks to the Mapbender Trac Master to avoid confusion. Let me know.
(It's more a technical finesse, as I'm already Trac Master. Check out
Mapbender role profiles at
http://www.mapbender.org/index.php/Category:Roles)
Baudson Christoph
http://www.wheregroup.com
More information about the Mapbender_dev mailing list
