AW: [Mapbender-dev] workgroup GDE: treeGDE2 - multilanguage for
thecontextmenue
Melchior Moos
Nimix at gmx.net
Tue May 8 06:17:09 EDT 2007
In treegde2 there are also other language specific strings:
9 alert strings and the 3 tooltips of the buttons on top. So implementing it with element vars would mean 20 new element vars, which I think is too much. In the long run I would prefer central language files for the hole mapbender so that you only need to define the language in mapbender.conf.
regards,
Melchior
Samson, Marko schrieb:
> Hi Astroid,
> I prefer the element_var solution. Even if there are little much vars for the GDE, I like the way to configure the GUI at one location. Having different location to configure one module causes confusion.
> Gruß,
> Marko Samson
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Tel.: 0251/91797 - 169
> Mail: marko.samson at wald-und-holz.nrw.de
>> -----Ursprüngliche Nachricht-----
>> Von: mapbender_dev-bounces at lists.osgeo.org
>> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
>> Astrid Emde (WhereGroup)
>> Gesendet: Dienstag, 8. Mai 2007 09:22
>> An: mapbender_dev at lists.osgeo.org
>> Betreff: [Mapbender-dev] workgroup GDE: treeGDE2 -
>> multilanguage for thecontextmenue
>> Hello devs,
>> there is a request for multilanguage in the new treeGDE2. The
>> text in the context menu (Move up, Move down, Hide...)
>> should be configurable.
>> At the moment the text is set in the mod_treefolder2.php
>> How can we solve it:
>> - element vars for every entry? - that would mean another 8
>> element vars
>> - treeGDE2.conf-file: file where the textes can be defined,
>> only one element var to include the conf-file (similar to the
>> solution of the element digitize - see element var:
>> digitize_conf_filename)
>> What do you think?
>> Greetings astrid
>> Astrid Emde
>> WhereGroup GmbH & Co.KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Fon: +49(0)228 90 90 38 - 19
>> Fax: +49(0)228 90 90 38 - 11
>> astrid.emde at wheregroup.com
>> http://www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Arnulf Christl, Olaf Knopp, Peter Stamm
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
"Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
More information about the Mapbender_dev
