AW: AW: [Mapbender-dev] workgroup GDE: treeGDE2 - multilanguage forthecontextmenue
Samson, Marko Marko.Samson at wald-und-holz.nrw.de
Tue May 8 09:03:24 EDT 2007
You're right, but what about stocking the translations into a table of the database or xml file or something like that, with a little simple user interface.
For example a select box for the different languages and two cols. One for the keyword and one for the desired translation.
It's little easier to manage, looks nicer and and the 'beautiful' admin gui would assure the position as one central configuration point.
BTW: I asked at the office, if I could join to PSC membership!---- If you want it, I would'n'could join the PSC! ;-)
Gruß,
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
> -----Ursprüngliche Nachricht-----
> Von: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von
> Melchior Moos
> Gesendet: Dienstag, 8. Mai 2007 12:17
> An: Mapbender Developer List
> Betreff: Re: AW: [Mapbender-dev] workgroup GDE: treeGDE2 -
> Hi,
> In treegde2 there are also other language specific strings:
> 9 alert strings and the 3 tooltips of the buttons on top. So
> implementing it with element vars would mean 20 new element
> vars, which I think is too much. In the long run I would
> prefer central language files for the hole mapbender so that
> you only need to define the language in mapbender.conf.
> regards,
> Melchior
> Samson, Marko schrieb:
> > Hi Astroid,
> > I prefer the element_var solution. Even if there are little
> much vars for the GDE, I like the way to configure the GUI at
> one location. Having different location to configure one
> module causes confusion.
> > Gruß,
> > Marko Samson
> > Marko Samson
> > Referat I-5
> > 48147 Münster
> von Astrid
> >> Emde (WhereGroup)
> >> Gesendet: Dienstag, 8. Mai 2007 09:22
> >> An: mapbender_dev at lists.osgeo.org
> >> Betreff: [Mapbender-dev] workgroup GDE: treeGDE2 -
> multilanguage for
> >> thecontextmenue
> >> Hello devs,
> >> there is a request for multilanguage in the new treeGDE2.
> The text in
> >> the context menu (Move up, Move down, Hide...) should be
> >> configurable.
> >> At the moment the text is set in the mod_treefolder2.php
> >> How can we solve it:
> >> - element vars for every entry? - that would mean another
> 8 element
> >> vars
> >> - treeGDE2.conf-file: file where the textes can be
> defined, only one
> >> element var to include the conf-file (similar to the
> solution of the
> >> element digitize - see element var:
> >> digitize_conf_filename)
> >> What do you think?
> >> Greetings astrid
> >>  Astrid Emde
> >>  WhereGroup GmbH & Co.KG
> >>  Siemensstraße 8
> >>  53121 Bonn
> >>  Germany
> >>  Fon: +49(0)228 90 90 38 - 19
> >>  Fax: +49(0)228 90 90 38 - 11
> >>  astrid.emde at wheregroup.com
> >>  http://www.wheregroup.com
> >>  Amtsgericht Bonn, HRA 6788
> >>  Komplementärin:
> >>  WhereGroup Verwaltungs GmbH
> >>  vertreten durch:
> >>  Arnulf Christl, Olaf Knopp, Peter Stamm
> >> _______________________________________________
> >> Mapbender_dev mailing list
> >> Mapbender_dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> "Feel free" - 10 GB Mailbox, 100 FreeSMS/Monat ...
> Jetzt GMX TopMail testen: http://www.gmx.net/de/go/topmail
More information about the Mapbender_dev mailing list
