[Mapbender-dev] PHP code comments
Marc Jansen
jansen.marc at gmx.de
Wed May 9 08:41:52 EDT 2007
Hi List,
Michael Schulz schrieb:
> Hi,
> I just realized that PHPDoc can only document one class per file. I
> don't know how often this is the case for the php classes, e.g.
> class_wms has one additional class (layer). I found this while trying
> PHPDoc at the sld editor classes.
> PHPDoc throws an ugly error if it comes to multiple classes in one
> file and functions, variables, etc. of the additional classes are
> merged under the first class.
> Should we therefore seperate each class in an individual file?
I would support your suggestion. BTW: Is there a pattern / suggestion on
naming files? My eclipse always suggests
xyz.class.php
when generating a new PHP class. Is this somehow a general PHP convention?
-- Marc
> Cheers, Michael
> 2007/5/7, Christoph Baudson (WhereGroup)
> <christoph.baudson at wheregroup.com>:
>> At the Mapbender Development sprint we agreed that we should start
>> commenting Mapbender code more thoroughly. Marc Jansen spearheaded this
>> initiative, volunteering to start commenting some PHP classes. Thanks
>> for your enthusiasm, Marc.
>> I recommend you start with the following PHP classes as I consider them
>> not to need a redesign in the near future:
>> classes/class_connector.php
>> classes/class_mb_exception.php
>> classes/class_administration.php
>> I recommend commenting the functions and their interfaces primarily.
>> As for JavaScript, I have already commented a file some time ago
>> javascripts/geometry.js
>> I believe PHP Doc and JS Doc are similar; maybe we can concentrate on
>> the similarities between the two, so we can use one style for both JS
>> and PHP. I would be happy if we could manage to coordinate our
>> commenting approach and achieve a single style.
>> Marc, please keep us updated; I would also be interested how turning
>> these comments into a valid HTML documentation works, as I have not
>> tried this with JS Doc.
>> Cheers
>> Baudson Christoph
>> http://www.wheregroup.com
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
