[Mapbender-dev] sld integration - first steps
Michael Schulz
mschulz at webgis.de
Fri May 11 05:24:07 EDT 2007
thanks, Christoph for your hints.
I have just updated the wiki page (
http://www.mapbender.org/index.php/Sld_integration
) with a suggestion of how to proceed with a first step of
implementation. Have a look at the section Implementation - Step 1.
Discussion should follow here.
Since these changes would affect basic classes, modules and the db
scheme who should actually make these changes? Module maintainers? I
could also provide code to be included by the module maintainers.
Step 1 should basically enable mapbender to request maps from a sld
enabled wms, using the SLD getMap request parameter.
Next steps should provide ways to set sld urls, e.g. from the
administration guis, or from other modules.
Cheers, Michael
2007/5/11, Christoph Baudson (WhereGroup) <christoph.baudson at wheregroup.com>:
> I believe as all as participants of this workgroup are members of this
> mailing list, it would be perfectly alright to discuss it here.
> You are already doing a great job documenting in the wiki at
> To make things perfect, you could add milestones to the roadmap at Trac at
> http://trac.osgeo.org/mapbender/roadmap
> and enhancement tickets, maybe just linking to the according wiki site.
> Thanks for your contribution!
> Michael Schulz schrieb:
> > Hi,
> > as mentioned in the sld workgroup results, i wanted to start
> > discussing the first steps of the sld integration. Should this be done
> > via the dev-list or a trac enhancement ticket? Maybe both, but one
> > after another: discuss it here, create a ticket with the result of the
> > discussion?
> > Michael
> Baudson Christoph
> http://www.wheregroup.com
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev
