[Mapbender-dev] sld integration - first steps
Sebastian Schmitz
sebastian.schmitz at wheregroup.com
Wed May 23 09:21:18 EDT 2007
I set up a demo Mapserver 4.10 WMS/WFS that we can use for SLD testing
purposes.
You can get the FeatureType name of the layer by a describeLayer
request. Then you can issue a WFS describeFetaureType request. URLs are
available at
http://www.mapbender.org/index.php/Sld_integration#WMS-SLD_Examples.
Cheers
Sebastian
Michael Schulz schrieb:
> Hi,
> thanks, Christoph for your hints.
> I have just updated the wiki page (
> ) with a suggestion of how to proceed with a first step of
> implementation. Have a look at the section Implementation - Step 1.
> Discussion should follow here.
> Since these changes would affect basic classes, modules and the db
> scheme who should actually make these changes? Module maintainers? I
> could also provide code to be included by the module maintainers.
> Step 1 should basically enable mapbender to request maps from a sld
> enabled wms, using the SLD getMap request parameter.
> Next steps should provide ways to set sld urls, e.g. from the
> administration guis, or from other modules.
> Cheers, Michael
> 2007/5/11, Christoph Baudson (WhereGroup)
> <christoph.baudson at wheregroup.com>:
>> I believe as all as participants of this workgroup are members of this
>> mailing list, it would be perfectly alright to discuss it here.
>> You are already doing a great job documenting in the wiki at
>> To make things perfect, you could add milestones to the roadmap at
>> Trac at
>> http://trac.osgeo.org/mapbender/roadmap
>> and enhancement tickets, maybe just linking to the according wiki site.
>> Thanks for your contribution!
>> > Hi,
>> > as mentioned in the sld workgroup results, i wanted to start
>> > discussing the first steps of the sld integration. Should this be done
>> > via the dev-list or a trac enhancement ticket? Maybe both, but one
>> > after another: discuss it here, create a ticket with the result of the
>> > discussion?
>> > Michael
>> Baudson Christoph
>> http://www.wheregroup.com
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Fon: +49 (0)228 / 90 90 38 - 24
Fax: +49 (0)228 / 90 90 38 - 11
mailto:sebastian.schmitz at wheregroup.com
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
More information about the Mapbender_dev
