[Mapbender-dev] using jquery ...
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Tue May 15 08:23:52 EDT 2007
Here's what I tried
$("div.listitem", parent.frames["digitize"].document).Draggable({ ...
where
$ = parent.frames['ajax'].window.$;
When I log through jQuery it seems like it works. I get an object
[Object HTMLDivElement] as a result of the "find" method.
But then the script halts and Firebug says
this.setArray() is not defined
Maybe that is due to the Draggable, which is a jQuery extension.
I will continue trying
Christoph
Michael Schulz schrieb:
> Hi Christoph, Marc,
> yes, I tried it, but to no avail. Here's a test code snippet:
> <html><head>
> <script type="text/javascript">
> i_$ = top.frames["ajax"].window.jQuery;
> i_$(document).ready(function() {
>        i_$("a",document).background("#f00");
> </script>
> </head>
> <body>
> <h1>MapBender jQuery Test page</h1>
> <a href="http://www.jquery.com">The jQuery library.</a>
> </body>
> INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
> e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
> e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
> e_target, e_requires, e_url) VALUES('gui1','test_jquery',10,1,'test
> jquery','iframe','../frames/mod_testjquery.html','frameborder="1"',980,25,250,200,NULL
> ,'visibility:visible;','','iframe','','','','','');
> Yep, I too think, the jquery mailing list is the next step.
> Cheers, Michael
> 2007/5/15, Christoph Baudson (WhereGroup)
> <christoph.baudson at wheregroup.com>:
>> Did you already try the context parameter Marc mentioned?
>> imported_$('div.test a', document);
>> I haven't given this subject enough time for a final conclusion; maybe
>> we should contact the jQuery mailing list?
>> Thanks for sharing
>> Christoph
>> > Hi,
>> > I've been fiddling around with this subject, and I think Christoph is
>> > right. jQuery has to be loaded in that frame you want to use it. You
>> > can then from that frame, reference elements in another frame and
>> > manipulate them. Not the other way round.
>> > Cheers, Michael
>> > 2007/5/14, Marc Jansen <jansen.marc at gmx.de>:
>> >> Christoph Baudson (WhereGroup) schrieb:
>> >> > I would be very interested in a solution. I use the jQuery
>> library in
>> >> > a separate frame, but want to locate html elements in another
>> iframe.
>> >> > Until now I didn't succeed. In this example
>> >> > > imported_$('div.test a').find('span').each(function(i) { ...
>> >> > the variable imported_$ only *points* to the jQuery library in the
>> >> > remote frame, so 'div.test a' will only find the div tags in the
>> >> > iframe where jQuery is loaded, and not in the intended iframe. At
>> >> > least that is my interpretation ;-)
>> >> Yepp, this might be true. yet one can pass over a context to search
>> >> within to the func:
>> >> _______________________________________________
>> >> Mapbender_dev mailing list
>> >> Mapbender_dev at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> Baudson Christoph
>> http://www.wheregroup.com
Baudson Christoph
More information about the Mapbender_dev mailing list
