[Mapbender-dev] using jquery ...
Michael Schulz mschulz at webgis.de
Tue May 15 08:35:30 EDT 2007
Hi Christoph,
i tried that approach too (fully referencing both iframes from the
top), but this is exactly the error message i get all the time...
Happens similar with the $(document).ready() thing, that is pure
jQuery no extensions.
Michael
2007/5/15, Christoph Baudson (WhereGroup) <christoph.baudson at wheregroup.com>:
> Here's what I tried
> $("div.listitem", parent.frames["digitize"].document).Draggable({ ...
> where
> $ = parent.frames['ajax'].window.$;
> When I log through jQuery it seems like it works. I get an object
> [Object HTMLDivElement] as a result of the "find" method.
> But then the script halts and Firebug says
> this.setArray() is not defined
> Maybe that is due to the Draggable, which is a jQuery extension.
> I will continue trying
> Christoph
> Michael Schulz schrieb:
> > Hi Christoph, Marc,
> > yes, I tried it, but to no avail. Here's a test code snippet:
> > <html><head>
> > <script type="text/javascript">
> > i_$ = top.frames["ajax"].window.jQuery;
> > i_$(document).ready(function() {
> >        i_$("a",document).background("#f00");
> > </script>
> > </head>
> > <body>
> > <h1>MapBender jQuery Test page</h1>
> > <a href="http://www.jquery.com">The jQuery library.</a>
> > </body>
> > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
> > e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
> > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
> > e_target, e_requires, e_url) VALUES('gui1','test_jquery',10,1,'test
> > jquery','iframe','../frames/mod_testjquery.html','frameborder="1"',980,25,250,200,NULL
> > ,'visibility:visible;','','iframe','','','','','');
> > Yep, I too think, the jquery mailing list is the next step.
> > Cheers, Michael
> >> Did you already try the context parameter Marc mentioned?
> >> imported_$('div.test a', document);
> >> I haven't given this subject enough time for a final conclusion; maybe
> >> we should contact the jQuery mailing list?
> >> Thanks for sharing
> >> Christoph
> >> > Hi,
> >> > I've been fiddling around with this subject, and I think Christoph is
> >> > right. jQuery has to be loaded in that frame you want to use it. You
> >> > can then from that frame, reference elements in another frame and
> >> > manipulate them. Not the other way round.
> >> > Cheers, Michael
> >> > 2007/5/14, Marc Jansen <jansen.marc at gmx.de>:
> >> >> Christoph Baudson (WhereGroup) schrieb:
> >> >> > I would be very interested in a solution. I use the jQuery
> >> library in
> >> >> > a separate frame, but want to locate html elements in another
> >> iframe.
> >> >> > Until now I didn't succeed. In this example
> >> >> > > imported_$('div.test a').find('span').each(function(i) { ...
> >> >> > the variable imported_$ only *points* to the jQuery library in the
> >> >> > remote frame, so 'div.test a' will only find the div tags in the
> >> >> > iframe where jQuery is loaded, and not in the intended iframe. At
> >> >> > least that is my interpretation ;-)
> >> >> Yepp, this might be true. yet one can pass over a context to search
> >> >> within to the func:
> >> >> _______________________________________________
> >> >> Mapbender_dev mailing list
> >> >> Mapbender_dev at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> >> Baudson Christoph
> >> http://www.wheregroup.com
> Baudson Christoph
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
