[Mapbender-dev] using jquery ...
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Tue May 15 08:43:22 EDT 2007
Hi Michael,
I tried a jQuery function instead:
$("div.listitem", parent.frames["digitize"].document).hide("slow");
This works for me now! But this one
$("div.listitem", parent.frames["digitize"].document).Draggable({ ...
is still a mystery to me.
Do you have the latest version of jQuery?
Cheers
Christoph
Michael Schulz schrieb:
> Hi Christoph,
> i tried that approach too (fully referencing both iframes from the
> top), but this is exactly the error message i get all the time...
> Happens similar with the $(document).ready() thing, that is pure
> jQuery no extensions.
> Michael
> 2007/5/15, Christoph Baudson (WhereGroup)
> <christoph.baudson at wheregroup.com>:
>> Here's what I tried
>> where
>> $ = parent.frames['ajax'].window.$;
>> When I log through jQuery it seems like it works. I get an object
>> [Object HTMLDivElement] as a result of the "find" method.
>> But then the script halts and Firebug says
>> this.setArray() is not defined
>> Maybe that is due to the Draggable, which is a jQuery extension.
>> I will continue trying
>> Christoph
>> > Hi Christoph, Marc,
>> > yes, I tried it, but to no avail. Here's a test code snippet:
>> > <html><head>
>> > <script type="text/javascript">
>> > i_$ = top.frames["ajax"].window.jQuery;
>> > i_$(document).ready(function() {
>> > i_$("a",document).background("#f00");
>> > </script>
>> > </head>
>> > <body>
>> > <h1>MapBender jQuery Test page</h1>
>> > <a href="http://www.jquery.com">The jQuery library.</a>
>> > </body>
>> > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment,
>> > e_element, e_src, e_attributes, e_left, e_top, e_width, e_height,
>> > e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod,
>> > e_target, e_requires, e_url) VALUES('gui1','test_jquery',10,1,'test
>> jquery','iframe','../frames/mod_testjquery.html','frameborder="1"',980,25,250,200,NULL
>> > ,'visibility:visible;','','iframe','','','','','');
>> > Yep, I too think, the jquery mailing list is the next step.
>> > Cheers, Michael
>> >> Did you already try the context parameter Marc mentioned?
>> >> imported_$('div.test a', document);
>> >> I haven't given this subject enough time for a final conclusion; maybe
>> >> we should contact the jQuery mailing list?
>> >> Thanks for sharing
>> >> Christoph
>> >> > Hi,
>> >> > I've been fiddling around with this subject, and I think
>> Christoph is
>> >> > right. jQuery has to be loaded in that frame you want to use it. You
>> >> > can then from that frame, reference elements in another frame and
>> >> > manipulate them. Not the other way round.
>> >> > Cheers, Michael
>> >> > 2007/5/14, Marc Jansen <jansen.marc at gmx.de>:
>> >> >> Christoph Baudson (WhereGroup) schrieb:
>> >> >> > I would be very interested in a solution. I use the jQuery
>> >> library in
>> >> >> > a separate frame, but want to locate html elements in another
>> >> iframe.
>> >> >> > Until now I didn't succeed. In this example
>> >> >> > > imported_$('div.test a').find('span').each(function(i) { ...
>> >> >> > the variable imported_$ only *points* to the jQuery library in
>> the
>> >> >> > remote frame, so 'div.test a' will only find the div tags in the
>> >> >> > iframe where jQuery is loaded, and not in the intended iframe. At
>> >> >> > least that is my interpretation ;-)
>> >> >> Yepp, this might be true. yet one can pass over a context to search
>> >> >> within to the func:
>> >> >> _______________________________________________
>> >> >> Mapbender_dev mailing list
>> >> >> Mapbender_dev at lists.osgeo.org
>> >> >> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
>> >> Baudson Christoph
>> >> http://www.wheregroup.com
>> Baudson Christoph
Baudson Christoph
More information about the Mapbender_dev
