[Mapbender-dev] Workgroup print: redesign
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu May 31 03:56:01 EDT 2007
Will this be part of the new release? If yes, remember the feature
freeze is starting tomorrow.
Sven Böhme (WhereGroup) schrieb:
> Hi list, hi workgroup print!
> I integrated the print of temporary elements (measured objects) into the
> mapbender print module (thanks Marc).
> I think this is a great moment to reassume the discussion about the
> redesign of the print module. I posted some informations in the
> mapbender wiki:
> http://www.mapbender.org/index.php/Mapbender_pdf-print_with_xml/xslt
> I hope that will start the process...
> Regards
> Sven
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
