[Mapbender-dev] JSDoc (was: JSDoc and compression)
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Thu May 31 06:14:22 EDT 2007
For the upcoming release I want to prepare JSDoc for the following files
geometry.js
map.js
point.js
map_obj.js
The documentation is of course not complete, as some parts are
undergoing a redesign. But a lot of classes are already fully documented.
With this API, programming will be much more efficient. At least I hope so.
The output of JSDoc is HTML only. There is no Wiki output. So where will
the files be put?
Christoph Baudson (WhereGroup) schrieb:
> I guess JSDoc is a good choice; maybe we should adopt it as well, as it
> is very similar to the PHPDoc Marc introduced. Any objections?
> With the introduction of JS-documentation packing or comment-stripping
> becomes inevitable to keep traffic at a minimum. The OpenLayers project
> is very clever about this, as they allow you to switch back and forth
> from a single compressed file to a developer version with multiple files
> and comments (Paul Spencer mentioned that in a previous post).
> I think we will have to learn how to do this too. It doesn't seem to be
> too difficult.
> Christoph
>>> Did we agree on how to document and comment JavaScript-Code? I forgot.
>> How about this one? http://jsdoc.sourceforge.net/
>> This is what the OpenLayers project uses as well.
>> Baudson Christoph
>> http://www.wheregroup.com
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Baudson Christoph
More information about the Mapbender_dev mailing list
