[Mapbender-dev] MS Windows certificated WMS (Typ PKCS .p12)
Roland Jehle r.jehle at ceit.at
Mon Nov 5 05:41:43 EST 2007
Hi Mapbendee-Devs!
I have a problem with a windows certificated WMS.
Unfortunately the provider gives the WMS only with a MS windows certificate
of type PKCS .p12 free.
As I have a UNIX-machine with Apache on the server it is not so easy to make
the WMS work.
As far as I know Mapbender sends the getMap-Requests via Javascript only
from the Client.
Actually it seems that the getMap request should come from a server, which
has this certificate working.
To send it to every Client is not the thing I want to do.
I'm testing to use Mapserver as Client for this WMS (connectiontype WMS)
from a certificated server.
May be someone has experience with this and a better solution!?
Lg + thanx
Roland
URL: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20071105/4da13314/attachment.html
More information about the Mapbender_dev mailing list
