[Mapbender-dev] Copyright Assignment
Marc Jansen jansen.marc at gmx.de
Mon Nov 19 04:04:45 EST 2007
Hi Arnulf,
hi devs,
I (without knowing too much about the legal stuff) think the option with
copyright transfer to the OSGeo  might be the best choice.  I read the
document  you suggested in IRC
(http://wiki.osgeo.org/index.php/Individual_Contributor_License_Agreement_%28CLA%29)
and personally think this sounds well.
What is the deal with single files that currently have the copyright
header set to something else than CCGIS?
Bye,
-- Marc
Arnulf Christl schrieb:
> Hi All,
> there is some legal stuff that we need to attend to. It is a dry topic
> so bear with me and I will try to make it as painless as possible.
> After we all understand the involved issues we should proceed to
> decide on how to go on.
> Mapbender sources are protected by the GNU GPL license. The initial
> code was release by the company CCGIS Christl & Stamm GbR who is also
> the copyright of Mapbender code. As CCGIS merged with two other
> companies to form the new WhereGroup GmbH & Co. KG. the Copyright now
> lies with the owners of the WhereGroup. But it does not say so in the
> sources.
> Now there are several options what we can do about this.
> * Leave as is (not recommended)
> * Change the header in all files and license texts to say WhereGroup
> GmbH & Co. KG (makes sense but there is no explicitly good reason to
> do it either)
> * Assign the copyright to OSGeo, change headers accordingly (recommended)
> We (CCGIS and now the WhereGroup) intentionally kept (almost) all code
> under CCGIS/WhereGroup because it makes things a lot easier than with
> several individual copyright holders. In the latter case it becomes
> very difficult to do change the license or the copyright (see the
> GeoTools example below) or protect developers (something that a
> Foundation could do) or sue license offenders (something that we would
> probably never *want* to do either).
> The name of the copyright holder (CCGIS) is not attached to a legal
> entity anymore (effectively as of the end of this year) we should
> reflect this in the code header and license texts.
> Therefore the WhereGroup has decided to assign the copyright to the
> Open Source Geospatial Foundation, something that other projects (for
> example GeoTools) is also trying to do. They have a lot more issues
> because unfortunately their copyright is owned by "the developers"
> which is not a legal entity. They now have trouble assigning copyright
> to a legal entity because they are not a legal entity. Therefore they
> are currently working on a document (still pending) that will assign
> copyright to OSGeo (look for CLA in the OSGeo Wiki).
> Our position is much clearer because we don't have the copyright
> distributed all over the place. We (the WhereGroup and some of the
> developers that I have already talked to individually) would like to
> go this way and assign copyright to OSGeo and be done with it.
> Well. I thought this would look more coherent! Friday evening is not
> the best time to start a thread  about this kind of stuff but before I
> throw it away again please give it a thought. Maybe you can just write
> to this list and share your opinions ask questions make suggestions
> word your qualms or whatever.
> Best regards, Arnulf.
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
