[Mapbender-dev] trac php source code?
Michael Schulz mschulz at webgis.de
Tue Nov 27 17:35:20 EST 2007
Frank,
thanks for your quick response. I did as you suggested:
http://trac.osgeo.org/osgeo/ticket/174
Cheers, Michael
2007/11/27, Frank Warmerdam <warmerdam at pobox.com>:
> Michael Schulz wrote:
> > Hi devs,
> > maybe asking the same question once again (i searched and found
> > nothing in the list ...):
> > Why can't the php source code be displayed in the trac source browser?
> > The trac FAQ suggest that it should be possible:
> > http://trac.edgewall.org/wiki/TracFaq#why-do-my-php-pages-show-up-blank-in-the-browser
> Michael,
> I think this FAQ has something do with actually interpreting PHP files,
> while you really just want to see the .php code viewable through the
> browser.
> If you file a ticket against component SAC in the OSGeo Trac:
> we can look into the issue.  I presume we just need to configure something
> in trac to render .php files as if they were plain text (which they are).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
