[Mapbender-dev] trac php source code?
Michael Schulz mschulz at webgis.de
Wed Nov 28 11:09:55 EST 2007
Hi Devs,
please note, that the php source code with syntax hiliting now works in trac.
Thanks to Frank.
Cheers, Michael
2007/11/27, Michael Schulz <mschulz at webgis.de>:
> Frank,
> thanks for your quick response. I did as you suggested:
> http://trac.osgeo.org/osgeo/ticket/174
> Cheers, Michael
> 2007/11/27, Frank Warmerdam <warmerdam at pobox.com>:
> > Michael Schulz wrote:
> > > Hi devs,
> > > maybe asking the same question once again (i searched and found
> > > nothing in the list ...):
> > > Why can't the php source code be displayed in the trac source browser?
> > > The trac FAQ suggest that it should be possible:
> > > http://trac.edgewall.org/wiki/TracFaq#why-do-my-php-pages-show-up-blank-in-the-browser
> > Michael,
> > I think this FAQ has something do with actually interpreting PHP files,
> > while you really just want to see the .php code viewable through the
> > browser.
> > If you file a ticket against component SAC in the OSGeo Trac:
> > we can look into the issue.  I presume we just need to configure something
> > in trac to render .php files as if they were plain text (which they are).
> > Best regards,
> > I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> > light and sound - activate the windows | http://pobox.com/~warmerdam
> > and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
> Michael Schulz
> in medias res
> Gesellschaft für Informationstechnologie mbH
> In den Weihermatten 66
> 79108 Freiburg
> Tel  +49 (0)761 556959-5
> Fax +49 (0)761 556959-6
> http://www.webgis.de / http://www.zopecms.de
Michael Schulz
in medias res
79108 Freiburg
More information about the Mapbender_dev mailing list
