[Mapbender-dev] mod_treefolder2
Melchior Moos
nimix at gmx.net
Fri Nov 30 06:08:27 EST 2007
I had a short look at it, the behavior of treefolder2 in trunk should be
like the old treefolder.php (line 605), but I'm not sure if that was the
correct way??
regards,
Melchior
> Hi,
> I know there is currently work done at improving mod_treefolder2, but
> nevertheless, this might make it into 2.4.4.
> I think there is a confusion in mod_treefolder2.php: To decide whether
> a layer should be ignored in the tree, it currently checks for
> gui_layer_selectable but should check against gui_layer_status.
> trunk:
> - lines 513 + 549
> 2.4.3:
> - the check whether layer 0 has status=0 is not present (BTW: if this
> is the case it should actually continue to the next wms not only to
> the next layer, in my opinion)
> - line 537
> Any other thoughts on this?
> Cheers, Michael
More information about the Mapbender_dev
