[Mapbender-dev] mod_treefolder2
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Fri Nov 30 02:59:21 EST 2007
Michael Schulz schrieb:
> Hi,
> I know there is currently work done at improving mod_treefolder2, but
> nevertheless, this might make it into 2.4.4.
Thanks for bringing it up, Michael. It won't make it in 2.4.4 rc1, but
surely into 2.4.4
I looked into the code, but as it's not my module, I would cause more
harm than good.
Christoph
> I think there is a confusion in mod_treefolder2.php: To decide whether
> a layer should be ignored in the tree, it currently checks for
> gui_layer_selectable but should check against gui_layer_status.
> trunk:
> - lines 513 + 549
> 2.4.3:
> - the check whether layer 0 has status=0 is not present (BTW: if this
> is the case it should actually continue to the next wms not only to
> the next layer, in my opinion)
> - line 537
> Any other thoughts on this?
> Cheers, Michael
Where2B-Konferenz
Die Lösungskonferenz der WhereGroup
am 29. November 2007 in Bonn
http://www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
olaf.knopp at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
