[Mapbender-dev] [Fwd: [Mapbender-commits] r1715 - in
trunk/mapbender/http: extensions frames javascripts]
Christoph Baudson (WhereGroup)
christoph.baudson at wheregroup.com
Mon Oct 8 04:48:14 EDT 2007
Just a quick note: We need to remove the frame reference to jQuery as well
window.frames['ajax'].
The AJAX module that loads jQuery in that IFrame is deprecated, see
http://www.mapbender.org/index.php/AJAX
Nimix, can you please remove this piece of code as well?
Thank you
Christoph
An embedded message was scrubbed...
Subject: [Mapbender-commits] r1715 - in trunk/mapbender/http: extensions
frames javascripts
Date: Mon, 8 Oct 2007 04:29:43 -0400 (EDT)
Url: http://lists.osgeo.org/pipermail/mapbender_dev/attachments/20071008/deceaa80/extensionsframesjavascripts.mht
More information about the Mapbender_dev
