[Mapbender-dev] [Fwd: [Mapbender-commits] r1715 - in trunk/mapbender/http: extensions frames javascripts]
Melchior Moos nimix at gmx.net
Mon Oct 8 05:04:46 EDT 2007
Hi Christoph,
thank you for reminding me. I did it in commit 1716.
Regards,
Melchior
Christoph Baudson (WhereGroup) schrieb:
> Just a quick note: We need to remove the frame reference to jQuery as
> well
>  window.frames['ajax'].
> The AJAX module that loads jQuery in that IFrame is deprecated, see
> http://www.mapbender.org/index.php/AJAX
> Nimix, can you please remove this piece of code as well?
> Thank you
> Christoph
> Betreff:
> javascripts
> Von:
> svn_mapbender at osgeo.org
> Datum:
> Mon, 8 Oct 2007 04:29:43 -0400 (EDT)
> An:
> mapbender_commits at lists.osgeo.org
> An:
> Author: nimix
> Date: 2007-10-08 04:29:43 -0400 (Mon, 08 Oct 2007)
> New Revision: 1715
> Added:
>    trunk/mapbender/http/extensions/jqjson.js
> Modified:
>    trunk/mapbender/http/frames/index.php
>    trunk/mapbender/http/javascripts/mod_savewmc.php
> Log:
> http://trac.osgeo.org/mapbender/ticket/113
> Added: trunk/mapbender/http/extensions/jqjson.js
> --- trunk/mapbender/http/extensions/jqjson.js	                        (rev 0)
> +++ trunk/mapbender/http/extensions/jqjson.js	2007-10-08 08:29:43 UTC (rev 1715)
> @@ -0,0 +1,96 @@
> +(function ($) {
> +    var m = {
> +            '\b': '\\b',
> +            '\t': '\\t',
> +            '\n': '\\n',
> +            '\f': '\\f',
> +            '\r': '\\r',
> +        s = {
> +            'array': function (x) {
> +                var a = ['['], b, f, i, l = x.length, v;
> +                for (i = 0; i < l; i += 1) {
> +                    v = x[i];
> +                    f = s[typeof v];
> +                    if (f) {
> +                        v = f(v);
> +                        if (typeof v == 'string') {
> +                            if (b) {
> +                                a[a.length] = ',';
> +                            a[a.length] = v;
> +                            b = true;
> +                a[a.length] = ']';
> +                return a.join('');
> +            'boolean': function (x) {
> +                return String(x);
> +            'null': function (x) {
> +                return "null";
> +            'number': function (x) {
> +                return isFinite(x) ? String(x) : 'null';
> +            'object': function (x) {
> +                if (x) {
> +                    if (x instanceof Array) {
> +                        return s.array(x);
> +                    var a = ['{'], b, f, i, v;
> +                    for (i in x) {
> +                        v = x[i];
> +                        f = s[typeof v];
> +                        if (f) {
> +                            v = f(v);
> +                                if (b) {
> +                                a.push(s.string(i), ':', v);
> +                                b = true;
> +                    a[a.length] = '}';
> +                return 'null';
> +            'string': function (x) {
> +                if (/["\\\x00-\x1f]/.test(x)) {
> +                    x = x.replace(/([\x00-\x1f\\"])/g, function(a, b) {
> +                        var c = m[b];
> +                        if (c) {
> +                            return c;
> +                        c = b.charCodeAt();
> +                        return '\\u00' +
> +                            Math.floor(c / 16).toString(16) +
> +                            (c % 16).toString(16);
> +                return '"' + x + '"';
> +	$.toJSON = function(v) {
> +		var f = isNaN(v) ? s[typeof v] : s['number'];
> +		if (f) return f(v);
> +	$.parseJSON = function(v, safe) {
> +		if (safe === undefined) safe = $.parseJSON.safe;
> +		if (safe && !/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(v))
> +			return undefined;
> +		return eval('('+v+')');
> +	$.parseJSON.safe = false;
> +})(jQuery);
> Modified: trunk/mapbender/http/frames/index.php
> --- trunk/mapbender/http/frames/index.php	2007-10-05 14:27:41 UTC (rev 1714)
> +++ trunk/mapbender/http/frames/index.php	2007-10-08 08:29:43 UTC (rev 1715)
> @@ -78,7 +78,7 @@
>  </style>
>  <script type='text/javascript' src="../extensions/jquery.js"></script>
> -<script type='text/javascript' src="../extensions/json.js"></script>
> +<script type='text/javascript' src="../extensions/jqjson.js"></script>
>  <script type='text/javascript' src="../javascripts/point.js"></script>
>  <script type='text/javascript' src="../javascripts/map_obj.js"></script>
>  <script type='text/javascript' src="../javascripts/wfs_obj.js"></script>
> Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
> --- trunk/mapbender/http/javascripts/mod_savewmc.php	2007-10-05 14:27:41 UTC (rev 1714)
> +++ trunk/mapbender/http/javascripts/mod_savewmc.php	2007-10-08 08:29:43 UTC (rev 1715)
> @@ -63,7 +63,7 @@
>  	var ind = getMapObjIndexByName(mod_savewmc_target);
>  	var generalTitle = "session";
>  	window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work sometimes
> -	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":1, "generalTitle":generalTitle, "mapObject":toJSONString(mb_mapObj[ind])}, function (result, status) {
> +	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":1, "generalTitle":generalTitle, "mapObject":$.toJSON(mb_mapObj[ind])}, function (result, status) {
> @@ -78,7 +78,7 @@
>  		generalTitle = prompt("Save WMC as...");
>  	window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work onunload
> -	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":0, "generalTitle":generalTitle, "mapObject":toJSONString(mb_mapObj[ind])}, function (result, status) {
> +	window.frames['ajax'].$.post("../php/mod_insertWmcIntoDb.php", {"saveInSession":0, "generalTitle":generalTitle, "mapObject":$.toJSON(mb_mapObj[ind])}, function (result, status) {
>  		alert(status + ": " + result);
> \ No newline at end of file
> Mapbender_commits mailing list
> Mapbender_commits at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_commits
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
