[Mapbender-dev] Re: [Mapbender] #120: replace ["..."] with dot
notation in JS
Marc Jansen
jansen.marc at gmx.de
Tue Oct 16 09:07:30 EDT 2007
Hey Christoph,
this example works like a charm:
var c = {}; // object
var d = {}; // object
c.test = "testvalue"; // dot on object
d["test"] = "testvalue"; // parens on object
alert( c.toJSONString() ); // alerts: {"test" : "testvalue"}
alert( c.toJSONString() === '{"test":"testvalue"}' ); // alerts: true
alert( d.toJSONString() ); // alerts: {"test" : "testvalue"}
alert( d.toJSONString() === '{"test":"testvalue"}' ); // alerts: true
alert( c.toJSONString() === d.toJSONString() ); // alerts: true
Can you post a minimal example that fails? Maybe it isn't the
toJSONString()-method that is the root of this error.
-- Marc
Mapbender schrieb:
> #120: replace ["..."] with dot notation in JS
> Reporter: christoph | Owner: mapbender_dev at lists.osgeo.org
> Type: refactoring | Status: new
> Priority: major | Milestone: 2.5 release
> Component: core | Version:
> Resolution: | Keywords:
> Comment (by christoph):
> 1. correct. I tried converting the map object to JSON via toJSONString(),
> and the entries for the arrays created with the bracket syntax were
> omitted. I had to use the dot syntax. Now I realize why JSLint always
> complains about the bracket syntax.
> 2. I mean the anyObject.toJSONString from json.js, which itself is from
> www.json.org
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
