[Mapbender-dev] Re: [Mapbender] #120: replace ["..."] with dot
	notation in JS
    Christoph Baudson (WhereGroup)
    christoph.baudson at wheregroup.com
    Tue Oct 16 09:12:13 EDT 2007
Thanks for your input Marc!
Try exporting the mb_mapObj from Mapbender, it is incomplete.
It may fail because some objects are initialised as arrays, see
/javascripts/map_obj.js.
Maybe try your example with
var c = [];
instead of {}
I would be curious if this failed. This could be the reason.
Nevertheless, going with a single style will improve readability and
minimize errors. I guess I will update the code conventions later on if
no one contradicts.
Cheers
Christoph
Marc Jansen schrieb:
> Hey Christoph,
> this example works like a charm:
> var c = {}; // object
> var d = {}; // object
> c.test = "testvalue";     // dot on object
> d["test"] = "testvalue";  // parens on object
> alert( c.toJSONString() );      // alerts: {"test" : "testvalue"}
> alert( c.toJSONString() === '{"test":"testvalue"}' );      // alerts:
> true
> alert( d.toJSONString() );      // alerts: {"test" : "testvalue"}
> alert( d.toJSONString() === '{"test":"testvalue"}' );      // alerts:
> true
> alert( c.toJSONString() === d.toJSONString() );  // alerts: true
> Can you post a minimal example that fails? Maybe it isn't the
> toJSONString()-method that is the root of this error.
> -- Marc
> Mapbender schrieb:
>> #120: replace ["..."] with dot notation in JS
>>   Reporter:  christoph    |       Owner:  mapbender_dev at lists.osgeo.org
>>       Type:  refactoring  |      Status:
>> new                            Priority:  major        |
>> Milestone:  2.5 release                   Component:  core
>> |     Version:
>> Resolution:               |
>> Keywords:
>> Comment (by christoph):
>>  1. correct. I tried converting the map object to JSON via
>> toJSONString(),
>>  and the entries for the arrays created with the bracket syntax were
>>  omitted. I had to use the dot syntax. Now I realize why JSLint always
>>  complains about the bracket syntax.
>>  2. I mean the anyObject.toJSONString from json.js, which itself is from
>>  www.json.org
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Where2B-Konferenz
Die Lösungskonferenz der WhereGroup
am 29. November 2007 in Bonn
http://www.where2b-conference.com
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
olaf.knopp at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
