[Mapbender-dev] Re: [Mapbender] #132: treegde2: wms opacity is lowered to 0 (fully transparent)
Michael Schulz mschulz at webgis.de
Tue Oct 30 09:09:43 EDT 2007
regarding the second paragraph of this ticket
>  This issue is also related to ticket #55 because when clicking on opacity
>  up/down the whole tree is closed, even when some branches where opened.
I have a question: this problems is due to the fact, that the c_menu
needs to be rebuilt and obviously therefore the whole tree needs to be
reloaded. When building the c_menu array, could we skip the test
"...&& (parseFloat(parent.mb_mapObj[i].wms[ii].gui_wms_mapopacity) < 1)..."
of lines 526,527? This test removes or adds either opacity_down or
opacity_up from the menu, but in my opinion this is not absolutely
necessary, since the final test if the opacity can be changed to
values below zero or above 1 is done in handleOpacity. And what
happens is that the menu always has the entries opacity up and down
(if configured).
By doing this there's no need to rebuild the tree anymore, isn't it
(opacity handling is the only time when this is done at runtime, i
think?)? What do you think
Cheers, Michael
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
