[Mapbender-dev] Version-number at mapbender.conf
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Sep 11 11:09:19 EDT 2007
Hi Marko,
your initiative is very much appreciated. I have a few suggestions
1) Maybe we should add an enhancement ticket in Trac
2) I'm not sure if you're aware that Bjoern Heuser/Christoph Strotmann
were interested in updating the setup as well. Maybe there can be synergy.
Bjoern/Christoph: If you are reading this, please let us know if you are
still interested, and please do share your thoughts.
3) Your suggestion sounds very comfortable. However, a db web user might
not have the rights to alter the tables. We would have to discuss if that
is a problem.
4) What might be a problem in Mapbender is this: You can call index.php
without checking your setup previously. I believe that it would make sense
to avoid calling index.php until the setup is ok. I have seen that in
Sahana (www.sahana.lk) if you want to take a look.
Thanks very much for working on Mapbender,
Christoph
On Tue, September 11, 2007 2:14 pm, Samson, Marko wrote:
> Hi devs,
> Astroid, sorry, Astrid and me just had a little mail-conference about the
> mapbender_setup.php.
> Summary of our thoughts:
> For the current mapbender_setup and the further development, it would be
> nice to have a version number at one central point, like the
> mapbender.conf.
> For the curent version, just for displaying it at the mapbender_setup.
> For further version, to create a dynamic update script for the installed
> version. (for example)
> Example:
> 1. mapbender.conf has version 2.4.0
> 2. mapbender.conf-dist has version 2.5.0 (or furture mapbender-setup
> script has the latest version number hardcoded)
> 3.The future mapbender-setup update function will get the required
> database changes from a historized database-changes file (txt,xml,json
> ...whatever?!)
> current version 2.4.0<->new version 2.5.0 = create an update script from
> version 2.4.1 up to 2.5.0 from database-changes file ......
> <version 2.4.1 changes>
> <CREATE TABLE layer_epsg_tmp AS SELECT DISTINCT * FROM layer_epsg;>......
> <version 2.5.0 changes>
> <ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname
> VARCHAR(50);>......
> 4. run script
> 5. and so on
> What do you think about a version number at the conf?
> What do you think about the idea for expand the mapbender_setup of
> mapbender with an update function? Any ideas or thoughts?!
> Greetings,
> Marko Samson
> Marko Samson
> Landesbetrieb Wald und Holz NRW
> GIS-Anwendungsentwicklung
> Referat I-5
> Albrecht-Thaer-Straße 34
> 48147 Münster
> Tel.: 0251/91797 - 169
> Mail: marko.samson at wald-und-holz.nrw.de
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
