AW: [Mapbender-dev] Version-number at mapbender.conf
Strotmann, Christoph
Christoph.Strotmann at sag.de
Mon Sep 17 06:33:56 EDT 2007
Hi!
An webbased setup for the Mapbender would make sense.
But needed customer-related an solution to install Mapbender without using web-browser (We wanted to use something like "Nullsoft Software Installer".)
Greetings
Christoph Strotmann
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Samson, Marko
Gesendet: Mittwoch, 12. September 2007 10:16
An: Mapbender Developer List
Betreff: RE: [Mapbender-dev] Version-number at mapbender.conf
Hi Christoph,
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of
> Christoph Baudson
> Sent: Tuesday, September 11, 2007 5:09 PM
> To: mapbender_dev at lists.osgeo.org
> Subject: Re: [Mapbender-dev] Version-number at mapbender.conf
> Hi Marko,
> your initiative is very much appreciated. I have a few suggestions
> 1) Maybe we should add an enhancement ticket in Trac
ok, I will do that
> 2) I'm not sure if you're aware that Bjoern Heuser/Christoph
> Strotmann were interested in updating the setup as well.
> Maybe there can be synergy.
> Bjoern/Christoph: If you are reading this, please let us know
> if you are still interested, and please do share your thoughts.
that would be nice!
> 3) Your suggestion sounds very comfortable. However, a db web
> user might not have the rights to alter the tables. We would
> have to discuss if that is a problem.
other projects, like joomal or sahana, have the same procedure, to install the db as web user.
> 4) What might be a problem in Mapbender is this: You can call
> index.php without checking your setup previously. I believe
> that it would make sense to avoid calling index.php until the
> setup is ok. I have seen that in Sahana (www.sahana.lk) if
> you want to take a look.
had a little test yesterday evening and created a new disaster! ;-)
think it is nice, but secondary. first we should create a complete installation routine before we can implement the 'setup_ok_check'.
we have to discuss, what category of errors while the 'setup_ok_check' prevent of calling the index.php and which errors are negligible....
> Thanks very much for working on Mapbender,
> Christoph
> On Tue, September 11, 2007 2:14 pm, Samson, Marko wrote:
> > Hi devs,
> > Astroid, sorry, Astrid and me just had a little
> mail-conference about
> > the mapbender_setup.php.
> > Summary of our thoughts:
> > For the current mapbender_setup and the further
> development, it would
> > be nice to have a version number at one central point, like the
> > mapbender.conf.
> > For the curent version, just for displaying it at the
> mapbender_setup.
> > For further version, to create a dynamic update script for the
> > installed version. (for example)
> > Example:
> > 1. mapbender.conf has version 2.4.0
> > 2. mapbender.conf-dist has version 2.5.0 (or furture
> mapbender-setup
> > script has the latest version number hardcoded)
> > 3.The future mapbender-setup update function will get the required
> > database changes from a historized database-changes file
> (txt,xml,json
> > ...whatever?!)
> > current version 2.4.0<->new version 2.5.0 = create an update script
> > from version 2.4.1 up to 2.5.0 from database-changes file ......
> > <version 2.4.1 changes>
> > <CREATE TABLE layer_epsg_tmp AS SELECT DISTINCT * FROM
> layer_epsg;>......
> > <version 2.5.0 changes>
> > <ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname
> > VARCHAR(50);>......
> > 4. run script
> > 5. and so on
> > What do you think about a version number at the conf?
> > What do you think about the idea for expand the mapbender_setup of
> > mapbender with an update function? Any ideas or thoughts?!
> > Greetings,
> > Marko Samson
> > Marko Samson
> > Landesbetrieb Wald und Holz NRW
> > GIS-Anwendungsentwicklung
> > Referat I-5
> > Albrecht-Thaer-Straße 34
> > 48147 Münster
> > Tel.: 0251/91797 - 169
> > Mail: marko.samson at wald-und-holz.nrw.de
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
