AW: [Mapbender-dev] Version-number at mapbender.conf
Samson, Marko
Marko.Samson at wald-und-holz.nrw.de
Fri Sep 28 06:13:26 EDT 2007
How far are your developments with your nullsoft project?
Do you know the nsis eclipse plugin:
http://eclipsensis.sourceforge.net
I used it for a little installer project (non mb project) and it was a great help.
Do you install Apache and Postgres/Postgis with the installer, too?
Or do you assume, that it is already installed or you check it while the installation routine?
Will you implement an update routine, too? If so, we could think about a consistent solution for webbased and installer update by using the same file, format, algorithm ideas etc.
Marko Samson
Marko Samson
Landesbetrieb Wald und Holz NRW
GIS-Anwendungsentwicklung
Referat I-5
Albrecht-Thaer-Straße 34
48147 Münster
Tel.: 0251/91797 - 169
Mail: marko.samson at wald-und-holz.nrw.de
-----Ursprüngliche Nachricht-----
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Strotmann, Christoph
Gesendet: Montag, 17. September 2007 12:34
An: Mapbender Developer List
Betreff: AW: [Mapbender-dev] Version-number at mapbender.conf
Hi!
An webbased setup for the Mapbender would make sense.
But needed customer-related an solution to install Mapbender without using web-browser (We wanted to use something like "Nullsoft Software Installer".)
Greetings
Christoph Strotmann
Von: mapbender_dev-bounces at lists.osgeo.org [mailto:mapbender_dev-bounces at lists.osgeo.org] Im Auftrag von Samson, Marko
Gesendet: Mittwoch, 12. September 2007 10:16
Betreff: RE: [Mapbender-dev] Version-number at mapbender.conf
Hi Christoph,
> -----Original Message-----
> From: mapbender_dev-bounces at lists.osgeo.org
> [mailto:mapbender_dev-bounces at lists.osgeo.org] On Behalf Of Christoph
> Baudson
> Sent: Tuesday, September 11, 2007 5:09 PM
> To: mapbender_dev at lists.osgeo.org
> Subject: Re: [Mapbender-dev] Version-number at mapbender.conf
> Hi Marko,
> your initiative is very much appreciated. I have a few suggestions
> 1) Maybe we should add an enhancement ticket in Trac
ok, I will do that
> 2) I'm not sure if you're aware that Bjoern Heuser/Christoph Strotmann
> were interested in updating the setup as well.
> Maybe there can be synergy.
> Bjoern/Christoph: If you are reading this, please let us know if you
> are still interested, and please do share your thoughts.
that would be nice!
> 3) Your suggestion sounds very comfortable. However, a db web
> user might not have the rights to alter the tables. We would
> have to discuss if that is a problem.
other projects, like joomal or sahana, have the same procedure, to install the db as web user.
> 4) What might be a problem in Mapbender is this: You can call
> index.php without checking your setup previously. I believe
> that it would make sense to avoid calling index.php until the
> setup is ok. I have seen that in Sahana (www.sahana.lk) if
> you want to take a look.
had a little test yesterday evening and created a new disaster! ;-)
think it is nice, but secondary. first we should create a complete installation routine before we can implement the 'setup_ok_check'.
we have to discuss, what category of errors while the 'setup_ok_check' prevent of calling the index.php and which errors are negligible....
> Thanks very much for working on Mapbender,
> Christoph
> On Tue, September 11, 2007 2:14 pm, Samson, Marko wrote:
> > Hi devs,
> > Astroid, sorry, Astrid and me just had a little
> mail-conference about
> > the mapbender_setup.php.
> > Summary of our thoughts:
> > For the current mapbender_setup and the further
> development, it would
> > be nice to have a version number at one central point, like the
> > mapbender.conf.
> > For the curent version, just for displaying it at the
> mapbender_setup.
> > For further version, to create a dynamic update script for the
> > installed version. (for example)
> > Example:
> > 1. mapbender.conf has version 2.4.0
> > 2. mapbender.conf-dist has version 2.5.0 (or furture
> mapbender-setup
> > script has the latest version number hardcoded)
> > 3.The future mapbender-setup update function will get the required
> > database changes from a historized database-changes file
> (txt,xml,json
> > ...whatever?!)
> > current version 2.4.0<->new version 2.5.0 = create an update script
> > from version 2.4.1 up to 2.5.0 from database-changes file ......
> > <version 2.4.1 changes>
> > <CREATE TABLE layer_epsg_tmp AS SELECT DISTINCT * FROM
> layer_epsg;>......
> > <version 2.5.0 changes>
> > <ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname
> > VARCHAR(50);>......
> > 4. run script
> > 5. and so on
> > What do you think about a version number at the conf?
> > What do you think about the idea for expand the mapbender_setup of
> > mapbender with an update function? Any ideas or thoughts?!
> > Greetings,
> > Marko Samson
> > Marko Samson
> > Referat I-5
> > 48147 Münster
> > Mapbender_dev mailing list
> > Mapbender_dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev
