[Mapbender-dev] session.conf
Uli Rothstein (WhereGroup)
uli.rothstein at wheregroup.com
Fri Aug 15 02:24:33 EDT 2008
Hello Christoph,
it's necessary to configure the session variables!
Maybe you get params from 'outside' (initial get/post parameters) or you
don't want to handle the informations about the registered user in the
sessions (other php-applications could use the same session).
So I think a conf-file is the right way to handle the variables....
regards
Uli
Christoph Baudson schrieb:
> why is session.conf a ".conf" file? Why not have a regular php file? I
> guess these entries are definitely not configurable.
> we should move the essential entries to a php file and only have
> customized entries in the conf file.
Ulrich Rothstein
WhereGroup GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
mailto:uli.rothstein at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
