[Mapbender-dev] Printing the Measurement
Christoph Baudson christoph.baudson at wheregroup.com
Fri Aug 15 09:50:10 EDT 2008
Christoph Baudson schrieb:
> Samson, Marko schrieb:
>> I just recognized, that the last clicked part of o stroke from a
>> lenght measurement does not apear at the pdf file. (2.5rc5)
>> The function addMeasuredItem from print_functions.php deletes the
>> last part of the measure-array, if the measure-array isn't a closed
>> polygon (first==last point):
>> 219         if (isClosedPolygon($theFullArr)) {
>> 220           $nr_of_points = count($theFullArr);
>> 221             $isClosed = TRUE;
>> 222         } else {
>> 223           $nr_of_points = count($theFullArr) - 1;
>> 224             $isClosed = FALSE;
>> 225         }
>> Is there a reason why? I just deleted the "-1" and everything works
>> fine.
> I guess this is a bug. Can you please file a ticket and commit the
> corrected version?
I committed the bug fix, see http://trac.osgeo.org/mapbender/ticket/276.
Thanks for letting us know.
> Thanks
> Christoph
>> Greetings,
>> Marko Samson
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
