[Mapbender-dev] Printing the Measurement
Christoph Baudson
christoph.baudson at wheregroup.com
Thu Aug 14 09:13:20 EDT 2008
Samson, Marko schrieb:
> I just recognized, that the last clicked part of o stroke from a lenght measurement does not apear at the pdf file. (2.5rc5)
> The function addMeasuredItem from print_functions.php deletes the last part of the measure-array, if the measure-array isn't a closed polygon (first==last point):
> 219 if (isClosedPolygon($theFullArr)) {
> 220 $nr_of_points = count($theFullArr);
> 221 $isClosed = TRUE;
> 222 } else {
> 223 $nr_of_points = count($theFullArr) - 1;
> 224 $isClosed = FALSE;
> 225 }
> Is there a reason why? I just deleted the "-1" and everything works fine.
I guess this is a bug. Can you please file a ticket and commit the
corrected version?
Thanks
Christoph
> Greetings,
> Marko Samson
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
