[Mapbender-dev] documentation
Christoph Baudson
christoph.baudson at wheregroup.com
Tue Feb 19 10:45:28 EST 2008
I'm going to move the documentation in the SVN to the release branches
folder, because different versions of Mapbender have different APIs.
Now, "documents" is a folder under "trunk". This is not enough.
I stumbled over the problem because I want to check in the automatically
generated documentation as part of a build process.
Cheers
Christoph
More information about the Mapbender_dev
