[Mapbender-dev] Re: SLD branch error msg
Michael Schulz mschulz at webgis.de
Thu Jan 3 17:16:35 EST 2008
Hi Joscha,
yes, the sld table defintion was missing, but this has been fixed, as
some other bugs. Please update your checkout.
Cheers, Michael
2008/1/3, Joscha Laubach <laubach at iai.uni-bonn.de>:
> Hi list,
> > using PHP4 will not solve your problem, as some functionality in
> > Mapbender 2.4.3 requires PHP5.
> Ah, good to know! Back to PHP5 then... :-)
> > You have two versions of mapbender running side-by-side? 2.4.3 and the
> > sld_branch? I have never used IIS with the ISAPI module, maybe this is
> > a source of the problem. With CGI it's no problem to have multiple
> > mapbenders running parallel - although I am not sure, what happens to
> > your authentication if you switch from one version into the other.
> Thanks for your CGI advice. I (re-)installed PHP5 and now I use the CGI
> module and it seems to work for both Mapbender installations!
> Except some error messages in the admin_en/WMS GUI settings menu:
> Warning: pg_prepare() [function.pg-prepare]: Query failed: ERROR: column
> sld.fkey_layer_id does not exist LINE 1: ...er AS gl left outer join
> sld_user_layer AS sld on sld.fkey_l... ^ in L:\Program
> Files\mapbender_sld\http\php\database-pgsql.php on line 172
> Warning: pg_execute() [function.pg-execute]: Query failed: ERROR:
> unnamed prepared statement does not exist in L:\Program
> Files\mapbender_sld\http\php\database-pgsql.php on line 176
> PHP Warning: pg_prepare() [function.pg-prepare]: Query failed: ERROR:
> column sld.fkey_layer_id does not exist LINE 1: ...er AS gl left outer
> join sld_user_layer AS sld on sld.fkey_l... ^ in L:\Program
> Files\mapbender_sld\http\php\database-pgsql.php on line 172 PHP Warning:
> pg_execute() [function.pg-execute]: Query failed: ERROR: unnamed
> Maybe I forgot one of the database updates?
> In my regular Mapbender 2.4.3 installation I don't get this errors
> (separate databases!).
> Regards, Joscha
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel  +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev mailing list
