[Mapbender-dev] check browser on activated java or popup blocker
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Wed Jan 16 02:59:29 EST 2008
Thanks for your code, Marc, I will take a look at it and report back to
the list.
Thanks for your time and best wishes,
Christoph
Manns, FB 62 schrieb:
> Hi  dev list,
> Because most of internet user's got a popup, or
> java-script blocker and in case of that mapbender can not be
> optimaly used,
> i' ve createted 2 new features in our mapbender
> to check this.
> 1.  for checking the browser on java-scripting:
>    i've made  some modifications in mod_map1.php!!
>    you can download it here
>    http:///geoportal.remscheid.de/tools/mod_map1.zip
> 2.  for checking the browser on activated popup-blocker
>      copy this 2 files into Mapbender folder
>      http/html
>        http://geoportal.remscheid.de/tools/check_popup.zip
>            insert this sql into a gui
>         INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public,
> e_comment, e_element, e_src, e_attributes, e_left, e_top, e_width,
> e_height, e_z_index,     e_more_styles, e_content, e_closetag,
> e_js_file, e_mb_mod, e_target, e_requires, e_url)
> VALUES('gui2','check_popup',2,1,'check the
>         Browser on activated popup
> Blocker','iframe','../html/check_popup.html','',1000,1000,1,1,NULL
> ,'visibility:hidden;','','iframe','','','','','');
>     this module open up a popup window after loading a gui......
> you can test this features in your own mapbender versions,
> and if you want to make some modifications in this modules
> or add something that i've forgotten to do
> you're welcome :-).
> greetings from Remscheid
> Marc Manns
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
