[Mapbender-dev] [Mapbender] #168: new database-field 'e_title' not
in 'update_postgresql_db.sql'
info at osgeo.org
Wed Jan 23 11:16:15 EST 2008
#168: new database-field 'e_title' not in 'update_postgresql_db.sql'
Reporter: FrankJaeger | Owner: mapbender_dev at lists.osgeo.org
Type: defect | Status: new
Priority: trivial | Milestone:
Component: database | Version: 2.4.4
Keywords: e_title,PostgreSQL |
After updating Mapbender to 2.4.4 the Admin-Function "copy gui" fails:
ERROR: column "e_title" does not exist in .../http/php/database-pgsql.php
on line 133
Reason: In /resources/db/update/update_postgresql_db.sql this change is
missing.
Run this SQL in Database:
ALTER TABLE gui_element ADD COLUMN e_title character varying(255);
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/168>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
