[Mapbender-dev] Discussion: Character sets (client encoding)
Michael Schulz
mschulz at webgis.de
Wed Jul 16 11:42:19 EDT 2008
> I would love to abandon the database option "ISO" as well, but I think we
> still need it. I was just referring to the client side encoding.
ok, was too overoptimistic :-)
>> It'll only require to set the webservers character set to UTF8 also?
>> Could this be a potential problem, e.g. with other software running on
>> the same server?
> I think Mapbender can explicitly set the encoding in all documents it sends
> and delivers. In how far is Apache involved?
If you define a default character set in apache (AddDefaultCharset)
this overrides all settings set via meta-tags, because apache settings
are in the http-header.
Cheers, Michael
>> Just playing devil's advocat, I think we'll eliminate a lot of
>> problmes with that.
>> Cheers, Michael
> Christoph
>> 2008/7/16 Christoph Baudson <christoph.baudson at wheregroup.com>:
>>> Arnulf Christl schrieb:
>>>> Christoph Baudson wrote:
>>>>> This is a proposal to serve UTF-8 encoded HTML pages only. In my
>>>>> opinion
>>>>> there is no need to serve ISO-8859-1 pages.
>>>>> All character set conversions (when interacting with a database) could
>>>>> be
>>>>> done in PHP. So the architecture would change from
>>>>> client: ISO/UTF8
>>>>> server: UTF8
>>>>> database: ISO/UTF8
>>>>> to
>>>>> client: ISO/UTF8
>>>>> server: UTF8
>>>>> database: ISO/UTF8
>>>>> This will simplify things a lot and would make Mapbender less
>>>>> error-prone. If anyone has any reason why we should still serve ISO
>>>>> pages,
>>>>> please step up. I have no idea why we should.
>>>>> Thanks,
>>>>> Christoph
>>>> You confuse me, I cannot see the difference?
>>> neither do I.
>>> Here's what I meant
>>> client: UTF8
>>> server: UTF8
>>> database: ISO/UTF8
>>> Christoph
>>> nr: copy and paste for beginners
>>>> _______________________________________________
>>>> Mapbender_dev mailing list
>>>> Mapbender_dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_dev
