[Mapbender-dev] Discussion: Character sets (client encoding)
Christoph Baudson christoph.baudson at wheregroup.com
Wed Jul 16 11:49:21 EDT 2008
Michael Schulz schrieb:
> Hi,
>> I would love to abandon the database option "ISO" as well, but I think we
>> still need it. I was just referring to the client side encoding.
> ok, was too overoptimistic :-)
>>> It'll only require to set the webservers character set to UTF8 also?
>>> Could this be a potential problem, e.g. with other software running on
>>> the same server?
>> I think Mapbender can explicitly set the encoding in all documents it sends
>> and delivers. In how far is Apache involved?
> If you define a default character set in apache (AddDefaultCharset)
> this overrides all settings set via meta-tags, because apache settings
> are in the http-header.
I meant explicitly sending http headers in PHP. Is this overridden by
Apache?
Christoph
> Cheers, Michael
>>> Just playing devil's advocat, I think we'll eliminate a lot of
>>> problmes with that.
>>> Cheers, Michael
>> Christoph
>>> 2008/7/16 Christoph Baudson <christoph.baudson at wheregroup.com>:
>>>> Arnulf Christl schrieb:
>>>>> Christoph Baudson wrote:
>>>>>> This is a proposal to serve UTF-8 encoded HTML pages only. In my
>>>>>> opinion
>>>>>> there is no need to serve ISO-8859-1 pages.
>>>>>> All character set conversions (when interacting with a database) could
>>>>>> be
>>>>>> done in PHP. So the architecture would change from
>>>>>> client: ISO/UTF8
>>>>>> server: UTF8
>>>>>> database: ISO/UTF8
>>>>>> to
>>>>>> client: ISO/UTF8
>>>>>> server: UTF8
>>>>>> database: ISO/UTF8
>>>>>> This will simplify things a lot and would make Mapbender less
>>>>>> error-prone. If anyone has any reason why we should still serve ISO
>>>>>> pages,
>>>>>> please step up. I have no idea why we should.
>>>>>> Thanks,
>>>>>> Christoph
>>>>> You confuse me, I cannot see the difference?
>>>> neither do I.
>>>> Here's what I meant
>>>> client: UTF8
>>>> server: UTF8
>>>> database: ISO/UTF8
>>>> Christoph
>>>> nr: copy and paste for beginners
>>>>> _______________________________________________
>>>>> Mapbender_dev mailing list
>>>>> Mapbender_dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
