[Mapbender-dev] Build script / SQL
    Christoph Baudson
    christoph.baudson at wheregroup.com
    Wed Jul 23 06:14:50 EDT 2008
Details at
http://www.mapbender.org/Talk:Deployment
Christoph Baudson schrieb:
> We still don't have an automated routine to generate the SQL dumps for
> a new release. The problems are the schema SQLs, as the data SQL is
> pretty much exchangeable for MySQL and PostgreSQL.
> I was thinking about this: Maybe create the ER model in Dia [1], and
> then use tedia2sql [2] to export the model to MySQL, PostgreSQL etc.
> The export is basically a Perl script which parses the XML saved by
> Dia. You have to misuse the UML syntax to get results though. A class
> corresponds to a table, an attribute corresponds to a column etc.
> We would have
> a) a tool to maintain the database structure
> b) an up-to-date image to teach the db structure to new Mapbender devs
> c) various output formats like MySQL, PostgreSQL, Oracle etc.
> There is even a tool to import PostgreSQL databases into dia,
> postgresql_autodoc [3], but it is far from perfect, but could be at
> least helpful.
> I have made a prototypical Dia file [4], covering only three tables.
> But it seems to work for both MySQL and PostgreSQL.
> Please share your valued opinion. Maybe you know a better way to solve
> this problem.
> [1] http://live.gnome.org/Dia
> [2] http://tedia2sql.tigris.org/
> [3] http://www.rbt.ca/autodoc/
> [4]
> https://svn.osgeo.org/mapbender/branches/testbaudson_dev/documents/mpbn25_.dia
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
