[Mapbender-dev] Motion to enhance the user/group model
Christoph Baudson christoph.baudson at wheregroup.com
Mon Jun 9 07:54:03 EDT 2008
Hi Len
before casting my vote I want to discuss one more thing. At the moment,
only users can own WMS and WFS. Is that some kind of a problem? Do we
want/need groups to own services?
Beside this point I'm positive on your motion, as it only adds
functionality. If you don't need the enhanced group model, you can stick
with the old model.
Thanks
Christoph
Len Kne schrieb:
> Greetings
> After discussion at the last several IRC meetings, I motion to:
> 1. Add a table mb_group_mb_group
> 2. Allow groups to own applications/guis
> 3. Allow an owner of a group to administer members of that group
> Background
> The overall goal of this motion is to simplify the administration of
> users, groups, and applications.  Allowing groups to be members of
> groups may reduce the number of groups needed in a Mapbender
> installation.  Allowing a group to "own" an application and owners of
> a group to edit members will help Mapbender installations with
> multiple administrators.  Some more details for the three parts.
> 1. Adding the table mb_group_mb_group will allow groups to be members
> of other groups.  This will simplify "read" access to applications by
> allowing a hierarchical structure of groups.  The table will consist
> of two columns, fkey_mb_group_id and fkey_mb_parent_group_id.  Minor
> changes will be needed in class_user to query the new table and
> determine user application permissions.  This change does not remove
> or change any current functionality of the user/group model.
> 2. Most of the pieces needed for groups to own applications are
> already in place, they just need to be enabled.  Currently
> gui_mb_group.mb_group_type is unused, but could perform the same
> function as gui_mb_user.mb_user_type.  The function getOwnerByGui in
> class_administration already queries to gui_mb_group.mb_group_type to
> assign application ownership, but most modules are currently not using
> this class.  As part of the administration module work this summer, I
> propose to change the modules to use this administration class.  The
> only step left for groups to own applications is to create a simple
> module for people to add the owner attribute to the table (similar to
> mod_gui_owner).  This change does not remove or change any current
> 2a. Optionally, it may make sense to combine the functionality of 1
> and 2 together.  Currently class_user creates an array with what
> applications a user has "read" access to and class_administration
> creates an array of owners with "write" access.  Combining these into
> one function would produce an array with user access level to an
> application (by including owner, they have write access).  This could
> allow for other levels of access ton an application in the future.
> 3. Currently users can only be edited by a single owner.  This makes
> it hard for Mapbender installations with multiple administrators to
> manage users - for example an administrator may not be able to manage
> a user that is using an application they manage because the user was
> created by another admin.  This change will create a class that will
> allow an owner of a group to fully manage members (users and other
> groups) of the group, including editing, creating, and deleting.  This
> way administrative functions could be distributed.  No new tables or
> fields (with the exception of the new table in 1) are needed for this
> motion.
> 3a. This motion could have security implications for current Mapbender
> installations depending on how groups are setup.  It is therefore
> recommended that a new variable be added to Mapbender.conf to allow
> administrators to enable/disable this functionality.
> Link to previous discussion
> http://lists.osgeo.org/pipermail/mapbender_dev/2008-June/001216.html
> Thanks
> Len
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
