[Mapbender-dev] Spatial request: WFS / WMS relation
Christoph Baudson
christoph.baudson at wheregroup.com
Fri Nov 21 03:13:36 EST 2008
Quite recently we were having a bit of trouble configuring a WMS in
order to work with a WFS. I opened the following ticket
http://trac.osgeo.org/mapbender/ticket/330
In a nutshell:
Up to now, the layer that is linked to the WFS configuration would have
had to be both visible and a querylayer (that is, queryable and
activated for querying). The reason was, that in certain scenarios, you
might only want to retrieve objects of a certain theme. Just imagine a
rich application with lots of different WMS / WMS relations. A spatial
request would produce endless results.
However, the querylayer attribute is by definition an attribute to
control a WMS feature info request. So coupling this with a WFS looks
now a little "forced" and misplaced.
My proposal is to remove the querylayer condition from the "if"
mentioned in the ticket. You could still deactivate the spatial request
by setting the layer to "not visible". So the only thing we would lose
in such a solution would be this: You were unable to exclude layers from
spatial request while having them visible at the same time.
Would this be a major change? Could this be part of 2.5.1 or would we
have to defer this to 2.6? Do I make any sense?
Let's discuss,
Christoph
Where2B-Konferenz
Die Geo-IT Konferenz der WhereGroup
vom 9.-10. Dezember 2008 in Bonn
Web: www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
