[Mapbender-dev] CSS file inclusion
Michael Schulz
mschulz at webgis.de
Thu Aug 13 06:00:00 EDT 2009
Yes yes yes!
Very good suggestion, Christoph. We maybe should also define some
rules howto use styles in order to avoid conflicting definitions - not
sure, but i think when including css definitions, they overwrite
earlier included definitions. So a modules css file has to use the
elemtent's/modules's scope, using corresponding selectors.
I'm in favor of this suggestion.
Cheers, Michael
2009/8/13 Christoph Baudson <christoph.baudson at wheregroup.com>:
> Hello,
> I wondered why all modules have to add their CSS files to the body element.
> This is not modular. I checked index.php and found that the SQL that queries
> the file/css entries from gui_element_vars is restricted to the element
> "body". I think that is not sensible.
> I recommend to change this to all non-iframe application elements. My SQL
> would read sth like this
> SELECT DISTINCT var_value AS var_value FROM gui_element AS ge,
> gui_element_vars AS gevWHERE ge.e_id = gev.fkey_e_id AND ge.fkey_gui_id =
> gev.fkey_gui_id AND ge.e_id = gev.fkey_e_id AND ge.e_element <> 'iframe' AND
> gev.fkey_gui_id = $1 AND gev.var_type='file/css'
> Then each module could come with its own CSS settings. In the past missing
> CSS files have been a major source for errors, mostly because people didn't
> add them to body (popup comes to mind).
> Let's discuss if this is a good approach. We could also do this for
> text/css.
> Christoph
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu
> _______________________________________
> W h e r e G r o u p GmbH & Co. KG
> Siemensstraße 8
> 53121 Bonn
> Germany
> Christoph Baudson
> Anwendungsentwickler
> Fon: +49 (0)228 / 90 90 38 - 15
> Fax: +49 (0)228 / 90 90 38 - 11
> www.wheregroup.com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Qualifizierte Open Source Schulungen bei der
http://www.foss-akademie.de/
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
+++ Bitte beachten Sie unsere neue Adresse und Durchwahl +++
Schwimmbadstraße 2
D-79100 Freiburg i. Br.
Tel: +49 (0)761 705798-102
Tel: +49 (0)761 705798-0
Fax: +49 (0)761 705798-09
http://www.webgis.de / http://www.zopecms.de
Geschäftsführer: Stefan Giese, Dr. Christof Lindenbeck
Eingetragen im Handelsregister HRB 5930 beim Amtsgericht Freiburg
More information about the Mapbender_dev
