[Mapbender-dev] I18n tutorial
Christoph Baudson (Wheregroup)
christoph.baudson at wheregroup.com
Thu Dec 3 02:42:19 EST 2009
Hi Astrid,
Astrid Emde schrieb:
> Hello devs, hi christoph,
> thanks for the new I18n module and the new I18n tutorial.
> Just a question:
> What do you think about a new [[Category:Modules with I18n]]? We could add
> this category to all modules that provide i18n. It would be a good way to
> get an overview on the modules with I18n.
> This is the list of the modules that provide i18n:
> printPDF
> digitize
> wfsSpatialRequest
> treeGDE2
> mod_addWMSfromfilteredList_ajax
> wfs_additional_spatial_search
> mb_listGUIs
> mod_measure.php
> mod_wfs_gazetteer_client
Good idea to mention it, we already have a category [1]. If you want to
update it, feel free to do it, very much appreciated. You could also
make this part of our "Done" [2] by adding this information to the
module documentation [3] site.
Thanks
Christoph
[1] http://www.mapbender.org/Category:Internationalized
[2] http://www.mapbender.org/Done
[3] http://www.mapbender.org/Module_documentation
> Best regards Astrid
> On Wed, November 18, 2009 4:23 pm, Christoph Baudson (Wheregroup) wrote:
>> Hi there,
>> we have prepared a new i18n mechanism for Mapbender 2.7.
>> There is a new module i18n, which collects content from other modules,
>> and only performs a single AJAX request to retrieve the translations from
>> the server side. In Mapbender 2.6, each module handled i18n individually.
>> Note: This module only handles gettext translations! There is no
>> solution for database solutions. However, database translations are somehow
>> deprecated. I guess we will aim to be gettext-only asap.
>> Adding i18n to your module is much easier now. There is also a new
>> tutorial [1] which should explain it all. Take a look, and let us know if
>> there are errors, or just correct them yourself.
>> Thanks,
>> Christoph
>> [1] http://www.mapbender.org/Internationisation_tutorial
>> Aufwind durch Wissen!
>> Qualifizierte OpenSource-Schulungen
>> bei der www.foss-academy.eu
>> _______________________________________
>> W h e r e G r o u p GmbH & Co. KG
>> Siemensstraße 8
>> 53121 Bonn
>> Germany
>> Christoph Baudson
>> Anwendungsentwickler
>> Fon: +49 (0)228 / 90 90 38 - 15
>> Fax: +49 (0)228 / 90 90 38 - 11
>> christoph.baudson at wheregroup.com www.wheregroup.com Amtsgericht Bonn, HRA
>> 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch: Olaf Knopp, Peter Stamm
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
vertreten durch:
More information about the Mapbender_dev
