[Mapbender-dev] Re: [Mapbender] #555: no metadata for dynamicly
added wms
mapbender_dev at lists.osgeo.org
Tue Dec 8 02:39:44 EST 2009
#555: no metadata for dynamicly added wms
Reporter: frankjaeger | Owner: dev
Type: defect | Status: new
Priority: minor | Milestone: 2.6.1
Component: treeGDE | Version: 2.6
Resolution: | Keywords: Metadata
Comment (by armin11):
The problem is, that the metadata is assigned per id and only services
which are registrated in mapbender have such an id. A possible solution
would be to parse th capabilities document and put this metadata into the
map object. But then there must be distinguished between mapbender stored
services (services with an mapbender ids) and external services!
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/555#comment:1>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev
